Seka Exceed RDC
murawzky
by murawzky
Deihlos91 wrote:
Fri Mar 31, 2023 9:09 am
Could you tell me please your height and your inseam length?
Would be great. thank you.
- inseam: 81 cm
- height: 175 cm
- arm length (from fingers to the joint): 73cm
- saddle height to bb: 71cm
- reach to the hoods (ends): 739mm
- reach to the center axis of the handlebars: 664mm
- currently I have been riding on 2.5cm spacers
Hope this helps somewhat :)
dsveddy
by dsveddy
I just wanted to update on the seatpost slipping issues:
I think a major contributor is that at the point I was inserting my seatpost, the bottom was actually hitting the seat tube cutout, slightly angling my post backwards, and likely undermining the friction the compressor could apply. I lopped off a ~3cm and now with a bit of park tool carbon assembly paste, no problems.
I really suggest everyone take a good hard look at how deep their seatpost sits. I don’t have a particularly low one either, the spec seatpost is just ridiculously long. Most people could probably benefit from taking some seatpost off.
skinnybex
by skinnybex
I just opened a claim with my bank regarding my deposit refunded. I've now sent 3 emails and no response. Horrible company Cycling100 so if your considering purchasing this frame I'd look for a different distributor.
23’ Cervelo Soloist / 6.88kg - 1x Crit Bike
22' Cervelo R5 / 6.35kg - Climbing Bike
22' Cervelo Caledonia 5 / 7.55kg - Travel Bike
21' Cervelo Aspero / 8.06kg - Gravel Travel Bike
23' Cervelo Aspero 5 / 8.25kg - Gravel Race Bike
Deihlos91
by Deihlos91
murawzky wrote:
Sun Apr 02, 2023 9:22 am
- inseam: 81 cm
- height: 175 cm
Thank you very much.
Do you use the seatpost with setback or the zero one?
Allround:
Elilee Blize XXE 24 Carbon Raw L Custom-6340g
Sunday:
Colnago V3Rs 22 (RCRD) 54s Custom-6890g
BW/Travel:
Cannondale Synapse 20 Hi Mod 56 Custom-7200g
Old:
Specialized SWorks Aethos Jet Fuel 56 Custom-6060g
dvq
by dvq
I ended up sending a followup email with ride@sekabikes.com telling them I need an update or I can file a dispute. They replied back saying my frame was ready for shipping this week and C100 would reach out for rest of payment.We'll see...
aleduc
by aleduc
For anyone interested, I reached out to SEKA and they told their direct shop for EU/North America should be available in approx 1 month.
cb6dro
by cb6dro
dvq wrote:
Tue Apr 04, 2023 4:21 pm
When did you place your deposit/order with C100?
dvq
by dvq
cb6dro wrote:
Wed Apr 05, 2023 8:00 am
December 24th, 2022
cb6dro
by cb6dro
dvq wrote:
Wed Apr 05, 2023 8:09 pm
December 24th, 2022
Thanks. Looking at the spreadsheet some who ordered around the same time as you have had their frames for a month or so.
windsurfingodie
by windsurfingodie
derkv wrote:
Mon Mar 13, 2023 9:16 pm
DeathClassic wrote:
Sun Mar 12, 2023 10:06 pm
derkv wrote:
Sun Mar 12, 2023 8:35 pm
Using Muc-Off carbon paste it doesn't slip for me (76kg). However after some months a creaking noise does appear, which then disappears after applying new paste.
I'm the same weight so will try something like that. Not sure if carbon paste can go off but it seems like the grit leaves mine real quick and just turns into a slick film. Which clearly isn't going to help! Did you put any on the wedge face itself?
Didn't put anything on the wedge face.
Thanks or the advice on the slipping seatpost and had issues with the seatpost slipping after about half hour. Took it to my bike mechanic and used carbon paste and didn't work. I followd your recommendation with the Muc Off and clean wedge post, and has worked so far on bumby roads. Thanks again
dvq
by dvq
cb6dro wrote:
Thu Apr 06, 2023 7:17 am
December 24th, 2022
I've added my data to the spreadsheet now, I see a lot of exceeds but not rdcs. It's getting later into the week and still no balance payment request or response from Cycling100, just SEKA.
dsveddy
by dsveddy
dvq wrote:
Thu Apr 06, 2023 6:47 pm
December 24th, 2022
I get the impression they paint frames in batches, those of us who got our frames within 10 weeks probably got lucky and ordered a blue frame right around the time Seka shipped a bunch of blue frames to C100.
Basically means it's one big game of roulette. Order the right color/model/size and you get yours quickly. Order wrong, and you end up waiting half a year.
derkv
by derkv
FYI: my plastic Garmin mount (supplied with the frame set/handle bar) broke/fractured a long time ago. I was using a (relatively heavy) gen1 Hammerhead Karoo. Wrote about a warranty replacement to C100 many times, never got a reply.
SEKA took over and handled it quickly. Go the replacement stuff today. Not just the plastic bit, but also the alloy bit and also some new adapter (Go Pro).
Happy with their service!
dsveddy
by dsveddy
Has anyone else had issues with seatpost creak/lateral play? I'm now realizing that the seatpost fits VERY slopily in the seat tube, and the compressor does very little to stabilize it. I get about 1 degree of side to side laterally (in the "roll axis") and it creaks like hell. Anyone else have this issue?
MartinHnik
by MartinHnik
Hi there, I'd like to get the integrated handlebars (380/100). According to Seka, there are adapters. Do you know if it will work with 2020 Venge?
