Bravo73
by Bravo73 on Thu Jun 15, 2023 11:25 pm
Thanks for highlighting this change.
I should just have enough time to update my SLX order to the new model.
2011 S-Works Tarmac SL3 (ex-Team Highroad)
2023 Canyon Aeroad CF SLX
Lina
by Lina on Fri Jun 16, 2023 12:17 am
I'm pretty sure they ditched the entire seatpost design and went with single depth seatpost design. It'd be almost impossible to clamp the old seatpost design with the new seat clamp. And there is not a single mention of the seatpost in any of the new bikes on the site. So expect a slightly harsher ride. Also 4k for SL build is now starting to look really tempting, even though I'd have to strip it to the frame pretty much.
thirdsun
by thirdsun on Fri Jun 16, 2023 6:38 am
NordicSal wrote: ↑Thu Jun 15, 2023 7:53 pm
I can see this being my next bike in a year or two - unless something drastic happens.
Do you guys reckon it will have fixed all the baby mistakes?
Not everyone had problems with the Aeroad. Mine works flawlessly and so do countless others you won't read about in forums like this one.
The new seatpost clamp should fix the remaining issues for those that would be affected otherwise. I'd say now is the time to get an Aeroad. In 2 years we might be closer to a major frame update.
- Canyon Aeroad CF SLX 8 Di2
- Cervelo Caledonia Rival eTap AXS
- Vitus Venon Evo
- Canyon Grail CF SL 8 Di2
tomtom
by tomtom on Fri Jun 16, 2023 12:53 pm
thirdsun wrote: ↑Fri Jun 16, 2023 6:38 am
+1 but I like the new "solution" much better than the ugly sleeve (which doesn't help much....)
Canyon Aeroad CFR
Canyon Grail CF
Ferdi77
by Ferdi77 on Sun Jun 18, 2023 2:38 pm
The first iteration of the canyon Aeroad cf slx was 7.57 kg without pedals - now we are at 7.88 kg. Quite significant weight increase.
TomS
by TomS on Sun Jun 18, 2023 6:23 pm
Ferdi77 wrote: ↑Sun Jun 18, 2023 2:38 pm
BTW - the assembly video on the Canyon site (also) shows the new clamping mechanism. Perfectly happy with mine with sleeve, great bike all around!
Ferdi77
by Ferdi77 on Sun Jun 18, 2023 6:35 pm
TomS wrote:Ferdi77 wrote: ↑Sun Jun 18, 2023 2:38 pm
Iam still sneaking around this bike - I think I’ll wait for one of the older 11 speed versions in the outlet…
thirdsun
by thirdsun on Mon Jun 19, 2023 7:05 am
Ferdi77 wrote: ↑Sun Jun 18, 2023 6:35 pm
I doubt you will find any 11 speed Aeroads in the outlet. Pretty sure they have all been sold a year ago when the updated 12 speed models were introduced.
If you want to save some money you should buy the Aeroads that are in the outlet right now. Those are 12 speed models with the seatpost sleeve.
- Vitus Venon Evo
Ferdi77
by Ferdi77 on Mon Jun 19, 2023 7:10 am
thirdsun wrote:Ferdi77 wrote: ↑Sun Jun 18, 2023 6:35 pm
There were some of the 21 models (11speed) in the outlet this year actually. Hesitated to buy one of them though.
tymon_tm
by tymon_tm on Mon Jun 19, 2023 3:25 pm
just noticed ths topic has 200+ pages...
anyway, can someone please briefly explain what are the differences between CFR and (also new?) CF SLX?
aside from weight (obviously) and some tweaks (seatpost? headset?) do they share the design? in other words - can i expect CF SLX to be equally *fast* as the CFR?
reason i ask - CF SLX with Ultegra and 1400 DTs is 1/3 cheaper than CFR on DA and 1100's, and only ~400 grams heavier...
kkibbler wrote: WW remembers.
thirdsun
by thirdsun on Mon Jun 19, 2023 6:13 pm
tymon_tm wrote: ↑Mon Jun 19, 2023 3:25 pm
It's the same frame geometry with a different layup / higher grade carbon. Unless money is no object it's absolutely unnecessary to spend on the CFR model. CF SLX is all you'll ever need. It's the value sweet spot.
- Vitus Venon Evo
