I have the current Alanera, it actually requires both the 9mm top cap and a 5mm "aero spacer."odonnebj wrote: ↑Thu Jul 06, 2023 11:34 pmIf you use the updated Deda Superbox Stem or the Alanera 1-piece bar/stem, you will use a different headset top cover that comes with them. That cover measures at 9mm stack height. If you want to run a slammed stem then that's all you need. Note, you don't use the 11mm (or the extra 5mm) cover that comes with the headset if you run the Superbox or Alanera. Those covers are provided so you can run a non-internally routed stem from any other manufacturer. Tons of optionality!Ypuh wrote: ↑Wed Jul 05, 2023 8:33 amHi guys, hope any of you can provide me some help on ADHX frame sizing and the DCR headset's stack height. I'm about 186cm with long legs (92.5cm inseam) and also I'm not blessed with much flexibility which puts a strain on my stack and reach. My Cervelo S3 (stack/reach is 605/395) is perfect slammed, which suits my ideal stack at around 612mm.
Looking at Time's geometry table this brings me to an XL frame size (601/397). All tube lengths are comparable to the S3's, however I'm worried that the Deda (S-)DCR headset adds too much stack height. From what I gathered here, a mandatory headset top cover seems to add ~11mm and a Deda Alanera cockpit requires another 5mm spacer, which would bring the total to about 601+11+5 = 617mm(?)
Sizing down usually isn't an option either. My saddleheight is about 81cm. With a 53cm seattube it would show more seatpost than frame which looks just as ridiculous as having spacers. Ideally I prefer to slam the larger frame.
Any tips/final advice on the Deda headset would be much appreciated. Another option might be to forgo the Deda Alanera in favor of the new Superbox DCX v2 stem that does not require an additional 5mm spacer(?) I'm perfectly happy with a seperate bar and stem.
Also, keep in mind the stem stack height of the Superbox and Alanera if you go that route. They're a little different from each other. It's all a game of millimeters.
Hope that helps!
See page 21 of the manual https://dedaelementi.com/pub/media/cata ... l-en_1.pdf
