Factor Ostro
anyone tried an eccentric t47 BB to drop the BB height a bit?
https://www.firstcomponents.com/bottom- ... ric/c247d/
I received a pair of Black inc forty five wheels last week. When I weighed it, it turned out to weigh 1600 grams which is 110 grams more than what black inc claims!!
- Front 692
- Rear 908
Included in the weight is the shimano body and the rim tape.
Is it a normal weight because 110 grams difference feels wrong?
- Front 692
- Rear 908
You shouldn't include rim tape or valves when weighing wheels, but manufacturers massaging published weights is nothing new. In my mind 1600g for a wheelset is verging on heavy whereas 1490g sounds light, so I can see why you're disappointed. It will make a difference when you're measuring the bike weight on a set of scales, but you won't notice riding, and the difference probably accounts for about 0.1% of your total system weight. If you're really not happy, you could send them back, but I wouldn't be confident that a replacement set would be significantly different. Perhaps call Factor and see what they have to say. Maybe they'll give you a discount!Milton wrote: ↑Wed Feb 15, 2023 9:21 amI received a pair of Black inc forty five wheels last week. When I weighed it, it turned out to weigh 1600 grams which is 110 grams more than what black inc claims!!
- Front 692
- Rear 908
Somethings up with the rear. My reynolds black label 65s are 764/900
Can anyone confirm that this is the Ostro's BB for SRAM? https://www.ceramicspeed.com/en/cycling ... r-sram-dub
I realized I haven't done any maintenance on mine yet, and I don't have the tool. I need the 12 and 16-tooth BB tool, correct?
this is what you want in BBCorrect:inertianinja wrote: ↑Sat Feb 18, 2023 7:32 pmCan anyone confirm that this is the Ostro's BB for SRAM? https://www.ceramicspeed.com/en/cycling ... r-sram-dub
https://www.bbinfinite.com/products/t47 ... gLXy_D_BwE
I'm not looking to replace the BB yet - just for the right tool to service the stock one.FactoryMatt wrote: ↑Sat Feb 18, 2023 7:38 pmthis is what you want in BBCorrect:inertianinja wrote: ↑Sat Feb 18, 2023 7:32 pmCan anyone confirm that this is the Ostro's BB for SRAM? https://www.ceramicspeed.com/en/cycling ... r-sram-dub
Ahh. 16 or 12 notch im not sure which tho count the notches
https://www.parktool.com/en-us/product/ ... ool-bbt-47
I bought the ceramicspeed one. I know I overpaid but I knew it would work......and it does.
https://www.ceramicspeed.com/en/cycling ... colnagot47
16 notches BTW
16 notches BTW
Do the DS / NDS bottom bearing cups open in different rotational directions?
does anyone have a good comparo or a closeup of the new steerer design vs old? does the new one still use that vertical metal bracket? which has the bonded-in preload thread?
Andres at Beyond Aero was kind enough to let me weigh a frame/fork. Great guy, highly recommend his shop.
Do these weights seem right? how does one build a 6.8kg race bike on this? is there really more than 150g in parts and paint vs a flicker 56? (assuming 900g isnt unobtainable?!)
56 frame, w/ both hangers and seat wedge 1140 grams
uncut fork, bonded threaded insert version 516 grams
Wow, that is heavy. IIRC my 2022 56 raw carbon/chrome was around 900 and the fork was about 400 after cutting. My fork steerer was open - no bonded threaded bits. White paint is never scale friendly.
