Classified hub - Is this the new big thing?
elmtree
by elmtree
PaulJ wrote:
Fri Feb 24, 2023 3:43 pm
Personally I think a larger small - big difference is really where the benefits of this will lie. While the ratio is ~0.7, essentially mimicking a conventional 2x front setup, it doesn't really solve a problem for me. But change that ratio and all of a sudden you have no overlap, 22 discrete gears. Or where you would normally have a 1x large range cassette, on a gravel bike for example, you can now get the same absolute range but with much closer jumps and double the gears in between. Plus there probably wont be the same weight penalty if you're ditching a heavy 11-42 cassette for this system.
It would be super cool, but one issue is that if you wanted to hang out around the point where the hub shifts. Your derailleur would be swinging from top to bottom cog. I think I tiny bit of overlap would be best, but having an 11-22 cassette and 1 tooth jumps until 22, then 2 tooth jumps up to 44 would be wild!
Or even do a 13-24 cassette and stick a 60 tooth chain ring on to up the drivetrain efficiency
PaulJ
by PaulJ
elmtree wrote:
Fri Feb 24, 2023 3:56 pm
A very good point - I'd not considered what the rear mech would be up to with it having to go from one extreme to the other when the hub shifts.
Back to me being a sceptic about the system I think :lol:
Tifosiphil
by Tifosiphil
Is no one mentioning Campaenarts apparently running this at the weekend with a 62t chainring?
jayjay
by jayjay
Tifosiphil wrote:
Fri Feb 24, 2023 4:58 pm
It has been discussed in this other thread:
viewtopic.php?f=3&t=169944
hansotto089
by hansotto089
Does anybody know how the Classified Powershift plays with the Di2 Semi-Synchro shift?
Lina
by Lina
Anyone asking for bigger gap do keep in mind that it becomes unusable if you have to dump the cassette every single time you switch the hub
Nickldn
by Nickldn
Lina wrote:
Fri Feb 24, 2023 7:57 pm
You'd almost think some of the posters in this thread have not riden a bicycle! :D
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
TobinHatesYou
by TobinHatesYou
Though on the other hand the “front shift” happens instantly with no change in chain wrap, so it can be done simultaneously with one rear derailleur shift completely seamlessly. With AXS, unless I turn on the automatic compensation shift, I have to do the two shifts sequentially.
Also in gravel where gear ranges and jumps are higher coupled with smaller chainrings, a bigger “front shift” jump would be less likely to force a multi-shift in the rear.
Lelandjt
by Lelandjt
hansotto089 wrote:
Fri Feb 24, 2023 7:01 pm
It can't be shifted under ANY load so I wouldn't want to be caught by a surprise automated "front" shift.
elmtree
by elmtree
Lelandjt wrote:
Fri Feb 24, 2023 8:52 pm
It can be shifted to to 1000w iirc. I think it's better than front derailleurs for shifting under load
Sock3t
by Sock3t
It's awesome but if you get a rear flat during a race you...lost your derailleur.
TobinHatesYou
by TobinHatesYou
Sock3t wrote:
Fri Feb 24, 2023 10:30 pm
Pros rely primarily on full bike swaps when able. In situations where they would be taking neutral wheels on a climb, then yes this could be a problem. If you flat on a climb, your race/stage is likely over anyway.
Sock3t
by Sock3t
TobinHatesYou wrote:
Fri Feb 24, 2023 11:41 pm
Yeah I'm not a pro. I'm a Cat 3 and I don't think the neutral car is going to have a wheel with a derailleur in the hub.
TobinHatesYou
by TobinHatesYou
Sock3t wrote:
Sat Feb 25, 2023 4:34 am
How often do you take neutral wheels? The only time I've ever had real neutral support in a lower category race was at Sea Otter. At Cascade Classic, "neutral wheels" meant anyone who put a spare in a SAG vehicle had access to anyone else's wheels if they flatted. With disc this was a problem because at the time I was set up with a 140mm rear. I was the only person who put disc wheels in the car so I was supposed to be the only one permitted to take my disc wheels. Instead the SAG driver let someone use both my spare wheels even though he was set up for 160mm rear.
Anyway if you are lucky enough to have a follow car, then it's on you to bring a spare wheel that works for your drivetrain…doesn’t matter if it’s Classified or 9-speed or AXS or what.
BigBoyND
by BigBoyND
Nickldn wrote:
Fri Feb 24, 2023 8:08 pm
The 16t jump on Shimano is fine for me. I would prefer 17t or 18t, though. The AXS 13t just seems like an idiotic way to increase tooth jumps on the cassette.
Couple reasons for my views:
1. I shift the rear hundreds of times for each FD shift so I'd rather have small jumps where I shift more often. I'm in the small ring only if I almost run out of range on the cassette.
2. I don't "dump" that many gears at once. Before an FD shift, cadence starts to slow (or speed up) until it's near the end of the comfortable cadence range, and then it shift close to the other end. In reality, I'm shifting maybe 2 gears in the back after an FD shift. If I had to shift 3-4, I wouldn't mind, if it meant having a tighter cassette for the same range.
