Classified hub - Is this the new big thing?
I’ve decided to go down the classified route for next bike, currently in build at LBS. Based on ENVE Melee and ENVE wheel set.. with SRAM setup.
I really like the concept and willing to invest in it. I like SRAM, but hate their FD.
I’ve got some big Alps riding later this year, so will be interesting to see how I get on…
Sometimes you have to take a punt/risk and see how it goes…
BigBoyND wrote: ↑Sat Feb 25, 2023 7:35 am
The 16t jump on Shimano is fine for me. I would prefer 17t or 18t, though. The AXS 13t just seems like an idiotic way to increase tooth jumps on the cassette.
Couple reasons for my views:
1. I shift the rear hundreds of times for each FD shift so I'd rather have small jumps where I shift more often. I'm in the small ring only if I almost run out of range on the cassette.
2. I don't "dump" that many gears at once. Before an FD shift, cadence starts to slow (or speed up) until it's near the end of the comfortable cadence range, and then it shift close to the other end. In reality, I'm shifting maybe 2 gears in the back after an FD shift. If I had to shift 3-4, I wouldn't mind, if it meant having a tighter cassette for the same range.
Going to a 13t jump in front has nothing to do with increasing the range in back. The 10t cog achieved that. Officially AXS supports only 1t more than a Shimano 12spd road RD.
A SRAM 10-33t cassette has a 330% range via a 23t difference.
A Shimano 11-36t cassette has a 327% range via a 25t difference.
A SRAM 10-36t cassette has a 360% range via a 26t difference.
SRAM bumped down to a 13t jump in front in order to keep compensation shifting to a minimum while still having equivalent range thanks to that 10t cog.
How much stock are you getting for buying one hub?willing to invest in it
I see a lot of people must ride with car support behind them. I imagine people designing a product and thinking about all those guys that drive with car support behind them.
Very nice and poor me that go out alone or with mates and we take our spares.
You need to look at range as a whole. Big-small to small-big. For the same drivetrain range, AXS requires bigger % jumps in the rear.TobinHatesYou wrote: ↑Sat Feb 25, 2023 10:31 amBigBoyND wrote: ↑Sat Feb 25, 2023 7:35 am
The tradeoff for fewer compensation shifts is larger jumps, is greater gearing overlap between big ring and small ring. This goes for any given top and bottom gearing you need.
BigBoyND wrote: ↑Sat Feb 25, 2023 11:22 am
You don't get it.
10-11-12 = 10%-9.1%
11-12-13 = 9.1%-8.3%
The jumps are larger in percentage because of the 10t cog. It's got nothing to do with the difference up front.
And because smaller rings are used, the absolute changes in gear-distance are not far off.
The decision to go with a 13t jump is driven by the use of the 10t cog. Going 13t up front didn't drive any changes in itself.
Lol you say I don't get it while missing my point about system range. I'm not talking about the 1t jumps (which are also bigger with Sram, as you pointed out). I'm talking about the fact that a smaller range at the front (13t vs 16t) requires greater range at the rear. The greater range at the rear requires greater jumps (more teeth) in the middle and top of the cassette.TobinHatesYou wrote: ↑Sat Feb 25, 2023 12:50 pmBigBoyND wrote: ↑Sat Feb 25, 2023 11:22 am
You don't get it.
10-11-12 = 10%-9.1%
If you want a 1:1 low gear and a 4.6:1 high gear, for example, these are your options:
Shimano 50/34 with 11-34
Sram 46/33 with 10-33
These are the jumps on the cassette:
Shimano 9.1%, 8.3%, 7.7%, 7.1%, 13.3%, 11.8%, 10.5%, 14.3%, 12.5%, 11.1%, 13.3% (ave. 10.8%)
Sram 10.0%, 9.1%, 8.3%, 7.7%, 7.1%, 13.3%, 11.8%, 10.5%, 14.3%, 16.7%, 17.9% (ave. 11.5%)
This is true. Be sure to report back on your experience with this build.
cycling / nature / music
Huh, every other planetary gear hub can't be shifted under load. I wonder what they did differently.elmtree wrote: ↑Fri Feb 24, 2023 9:27 pmIt can be shifted to to 1000w iirc. I think it's better than front derailleurs for shifting under loadLelandjt wrote: ↑Fri Feb 24, 2023 8:52 pmIt can't be shifted under ANY load so I wouldn't want to be caught by a surprise automated "front" shift.hansotto089 wrote: ↑Fri Feb 24, 2023 7:01 pmDoes anybody know how the Classified Powershift plays with the Di2 Semi-Synchro shift?
Interesting, no? I think there is something clever inside - I suppose we won't soon find out what.Lelandjt wrote: ↑Sat Feb 25, 2023 5:48 pmHuh, every other planetary gear hub can't be shifted under load. I wonder what they did differently.elmtree wrote: ↑Fri Feb 24, 2023 9:27 pmIt can be shifted to to 1000w iirc. I think it's better than front derailleurs for shifting under loadLelandjt wrote: ↑Fri Feb 24, 2023 8:52 pmIt can't be shifted under ANY load so I wouldn't want to be caught by a surprise automated "front" shift.hansotto089 wrote: ↑Fri Feb 24, 2023 7:01 pmDoes anybody know how the Classified Powershift plays with the Di2 Semi-Synchro shift?
But shifting under load is for real. There are GCN videos of it, reviewers mention it and it's a key part of their marketing pitch - under load and virtually instantaneous.
Because it's got 1:1 and a lowrange gear. I'm pretty sure they just lock the entire hub into one when going to the 1:1 ratio. So it's not actually changing gears in the planetary. That's also how they will have 100% efficiency in the 1:1 ratio.Lelandjt wrote: ↑Sat Feb 25, 2023 5:48 pmHuh, every other planetary gear hub can't be shifted under load. I wonder what they did differently.elmtree wrote: ↑Fri Feb 24, 2023 9:27 pmIt can be shifted to to 1000w iirc. I think it's better than front derailleurs for shifting under loadLelandjt wrote: ↑Fri Feb 24, 2023 8:52 pmIt can't be shifted under ANY load so I wouldn't want to be caught by a surprise automated "front" shift.hansotto089 wrote: ↑Fri Feb 24, 2023 7:01 pmDoes anybody know how the Classified Powershift plays with the Di2 Semi-Synchro shift?
Unless there's some sort of a freewheel so that the planetary is engaged the entire time, just not connected to the rest of the hub when on the big ring. So all it changes on gear changes is disengage the hub locking and engage the planetary when changing to low range. And vice versa when changing to the big ring. Something similar is how I'd do it. They pretty much have to lock the hub for the 1:1 ratio because that's the only way they get 100% efficiency on the big ring. And they pretty much have to have the planetary engaged the entire time to be able to change under load.
I've had a 10 minute ride on a bike with a Classified hub, one of their demo bikes. Shifting is more or less instantaneous and there is no requirement to alter your pedalling while shifting.
