Hexsense wrote: ↑Fri Jul 31, 2020 6:22 pm
Pato wrote: ↑Fri Jul 31, 2020 10:28 am
Hexsense wrote: ↑Thu Jul 30, 2020 7:24 pm
Looking good on may details.
Not so when looking at geometry table though. Seems to use single fork for every sizes with varying head tube angle.
They make it handle well for medium size but made minimum effort to scale the bike down again. XS and XXS size rider should avoid such bike.
I'm the kind of rider who usually uses an XS or XXS (around 375 Reach / 500 Stack) and don't see anything wrong with it, as a matter of fact it's the only bike I've seen that has a decent wheelbase, most XS/XXS are around 970mm which translate into a very twitchy handling, especially with a steep HA and long fork offset.
For the tests I've done, I'd prefer a shorter fork offset (42mm) and slacker HA of around 69.5º/70º to compensate for wheelbase and avoid toe overlap with 410mm chainstay.
69.5 HTA and 42mm fork offset make it 82mm trail. That's slower handling than most Gravel bike.
If it is really that good then bike size medium and up where there is no such toe overlap limitation like smaller size would jump on this kind of slow handling geometry. But no, medium size and up racing road bikes gravitate to neutral handling around 56-62mm trail.
Smaller rider shouldn't have to tolerate geometry that is not even close to ideal like medium size and up. We can get long wheelbase and also the same neutral handling (rather than slower) with more fork offset rather than just making head tube more slack alone. Cannondale, Specialized, Cervelo etc. are all doing this quite right.
Look at Cannondale SuperSix Evo size 48 or SystemSix size 51. SuperSix Evo size 48 have 985mm wheelbase and 58mm trail. The bike has only 375mm reach too, unlike Reacto size XS which make it 384mm. They achieve it through 71.2degree HTA pair with 55mm fork offset. More fork offset in the smaller size is what needed to keep small bike have long wheelbase (with not so long reach/ top tube length) and handle the same way as larger bikes (with similar/same trail value). Unfortunately, it's where many manufacturers cut the cost by not offering it.
And why would you need faster handling when you're usually going above 33km/h on straight roads except when going uphill, and even twisty roads for a bike are still pretty much straight.
Stability and grip while leaning is a factor to consider, which short trail pretty much does not help it actually does quite the oppposite. A short trail and too much fork offset reduces grip when leaning the bike into a corner at 50km/h.
This geometry made much more sense with 19mm tires 30y ago, but as rubber is getting wider geometry should adapt to take the most benefit out of it.
I understand fast handling is necessary in a parking lot going around cones but that's not what road cycling is about, which is speed. At speed you lean countersteering, anybody who comes from motorcycle racing knows how that works.
Road cycling in one of the most conservative sports there is, the use of tubulars and strict UCI rules already proves that. Bike geometry is basically unchanged for the last 30 years except for seat tube angle and most probably it won't change, not because it's perfect but just because that's the way it is.
