OPEN releases road bike
Braking 101 is to not start braking by grabbing a fistful of your brake lever. If you have problems with constantly locking your rear wheel in sudden situations then you have also problems with going over the bars in the same situation, or even worse you completely avoid the front brake because you fear going over the bars.
I thought the same, the OPEN UP was a genuinely novel design. This isn't, nothing really jumps out other than the deficiencies like the ISP and oddly sized rear rotor, not to mention the price...
looks like a TCR. but if you need that hipster cred and have money to burn...
ISP, weird IS lower, not even that light, very short reach. Who is the target market?
The reach is more towards where reach should actually be for most people. Reach on most modern road bikes is just too long (evidenced by the stack of spacers under most bikes)TobinHatesYou wrote: ↑Mon May 25, 2020 5:32 amISP, weird IS lower, not even that light, very short reach. Who is the target market?
Then the medium should have a 570-575mm worth of stack. 560mm is neither here nor there...it's taller than Trek's H2, but not as tall as a typical endurance bike.
