OPEN releases road bike
- alexneumuller
- Contact:
There seems to be no info in regards of the isp length from BB. I usually have saddle 82.5cm from BB. Is there any more info for this?
Alex - you and me both!
I am going to find out more about this one.....
Warning - Inherently biased:
www.bespokecycling.com
- alexneumuller
- Contact:
The sizing is a little different...and I don’t understand why companies don’t release BB to a top of ISP length.....I have long legs, but don’t want or need a long TT, got a short upper body.bespoke wrote:Alex - you and me both!
Why is that "wild"?
Obviously the geometry is different, but other than that this frame is in some way similar to the new giant TCR SL: no dropped seat stays, no full cable integration, no "full aero", integrated seatpost, the design where the seat stays meet the seattube, 32mm tire clearance. David and Goliath heading in a similar direction (conceptually)?
Looks like a gorgeous bike... Odd that the headtube doesn't look super compact / short yet all the marketing pics show a ton of spacers under the stem which you wouldn't expect for a bike designed for more endurance / comfort.
Yeah the 160 rear rotor is a weird way to go. On the front is ok I suppose but in rear not really. Most popular combination even in Pro peloton is 160 front and 140 rear. Smaller rear rotor limits the chance of locking the wheel and is basically a safer option in my opinion.
Functionality > Performance > Weight
And its already "difficult" (not really difficult but surely requires some attention) not to lock the rear wheel on 140mm, can't imagine on 160.madik wrote: ↑Sat May 23, 2020 9:10 amYeah the 160 rear rotor is a weird way to go. On the front is ok I suppose but in rear not really. Most popular combination even in Pro peloton is 160 front and 140 rear. Smaller rear rotor limits the chance of locking the wheel and is basically a safer option in my opinion.
Not the end of the world eh, but as you say, weird.
I don't have any concerns about locking, because of the great modulation of any modern system.madik wrote: ↑Sat May 23, 2020 9:10 amYeah the 160 rear rotor is a weird way to go. On the front is ok I suppose but in rear not really. Most popular combination even in Pro peloton is 160 front and 140 rear. Smaller rear rotor limits the chance of locking the wheel and is basically a safer option in my opinion.
I always thought that the space for 160 mm is simply missing due to the aim for narrow chainstays/seatstays.
In typical controlled braking its not an issue with 160/160. The modulation is fine enough and most of the time its not required to brake as hard as possible. However when its required to start braking suddenly and fast the chance of locking going up qiute a bit and not many people have the skill to avoid it.
I'm not talking about normal conditions, rather in specific cases (eg hard corners with sudden braking, steep descents, damp weather.. ).icantaffordcycling wrote: ↑Sat May 23, 2020 9:59 amDo you have claws for hands? I don't see how it could possibly require attention to not lockup your rear wheel.
Anyway I'll rest my case, from other comments I understand that this is a contest on who's the best bike handler, happy that some people never found themselves to brake suddenly, or even if they did, their computer brain instantly calculated the perfect amount of hand pressure to apply to the brake lever.
