2020 Specialized Tarmac SL7
Vuong05
by Vuong05
MarkMcM wrote:
Fri Feb 24, 2023 4:23 pm
Maddie wrote:
Fri Feb 24, 2023 11:27 am
The transition part between stem and spacers is different. The rest is the same
Not in my experience. My SL7 came with a 6 deg. S-Works Tarmac SL7 stem, and I swapped it to a 12 deg. S-Works Tarmac SL7 stem without changing any other parts - same top cover, spacers and transition.
Same for me, switched from a 6 deg. to 12 deg. SL7 stem, without changing any other parts.
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg) I Specialized Allez Sprint 2022 : Heavy (7.62kg)
Maddie
by Maddie
Ah, it's possible that I mix this up with my Venge. Sorry
eins4eins
by eins4eins
perfect, thanks guys.
Jaisen
by Jaisen
BBres wrote:
Fri Feb 24, 2023 11:50 am
LP119 wrote:
Thu Feb 23, 2023 11:45 am
Hi all,
I'm waiting for my new SL7 Expert to arrive and I'm looking to buy an aero handlebar and there's currently no stock for the Roval Rapide. On the Seka website they mentionned that their integrated handlebar is compatible with the SL7 but I've never seen anyone running this. There's not much info on this but wanted to know is somone already tried and what it looked like?
Thanks!
I'd go with a Pro Vibe Aero SL and make it look just like a Remco's setup. I've got this handlebar and it's superb.
I also have this bar and can confirm it is very comfortable and stiff. Highly recommend.
macwatt
by macwatt
Hi
Looking for help for aero bar for my Tarmac SL7. I currently have Aerofly 2 in a 40cm which I feel is slightly too wide I have been searching found a few below would appreciate any advice or recommendations which are fully compatible. I would require 36-38cm centre to centre bar with similar reach of Aerofly 2 which I think is 80mm
Thanks
https://www.singletrackbikes.co.uk/m7b0 ... ars_-_Drop
https://ogevkinbike.com/collections/han ... dlebar-eu-
https://www.wiggle.co.uk/prime-primaver ... -handlebar
https://www.santafixie.co.uk/pro-plt-ca ... black.html
Regards
James
marian
by marian
And what about Pro Vibe Aero SL ? Also available in a width of 38 cm (C-C) with a reach of 80 mm I have 42 cm, satisfied
macwatt
by macwatt
marian wrote:
Sat Feb 25, 2023 5:30 pm
Thanks for the reply do you know the measurements of your bar outside to outside at hoods and drops? 💦 my 400mm Aerofly 2 is 420mm across the hoods and just under 430mm at the drops with tape installed. The reason I ask is I want to be sure going one size down will be sufficient.
GONE4ARIDE
by GONE4ARIDE
Great suggestion. I have a 40cm on my S-Works Tarmac SL6 and I love it. Good luck finding one though.
ODC
by ODC
GONE4ARIDE wrote:
Sat Feb 25, 2023 6:06 pm
In europe enough stock of this handlebar.
GONE4ARIDE
by GONE4ARIDE
ODC wrote:
Sat Feb 25, 2023 6:08 pm
You are fortunate. Availabililty of Pro components here in the USA has been virtually non-existent for the past 12-18 months.
marian
by marian
terrible, I bought them last september. Maybe luck, they arrived within a week of ordering in lbs
macwatt
by macwatt
Thanks
I have ordered Pro Vibe Aero SL 380mm
If anyone is interested in Specialized Aerofly 2 400mm it's in very good condition only reason for selling is the width please let me know.
marian
by marian
Thanks for the reply do you know the measurements of your bar outside to outside at hoods and drops? Image my 400mm Aerofly 2 is 420mm across the hoods and just under 430mm at the drops with tape installed. The reason I ask is I want to be sure going one size down will be sufficient.
at hoods 44 cm , same on the bottom.
See dimension W1,W2. It's still center-center, but you can see that the bars have a constant width everywhere
macwatt
by macwatt
Forgot to ask does Specialized Computer Mount work with the Pro Vibe Aero SL?
Jaisen
by Jaisen
macwatt wrote:
Sat Feb 25, 2023 9:16 pm
The out front computer mount attaches to the stem cap so yes it'll be fine with any bar.
