Scott Addict Disc 2020
Neillp
by Neillp
vanitypl wrote:
Sun Mar 12, 2023 2:18 am
RDY wrote:
Wed Mar 08, 2023 1:38 pm
Do normal 1 1/4" stems fit on the Addict / Addict Gravel steerer without a shim?
Yeah it's a standard round steerer, you just have to either make sure that the stem is compatible with the same kind of internal cable routing or be ok with a slightly messy cockpit.
I'm currently running standard round spacers (apart from the bottom one to cover the headset) and a 1 1/4 Foil stem.
It looks a little clunky with the hoses running under the stem into the headset, but it's easy to work on and lighter than the stock brick which is all I really care about.
I don't suppose you have a picture of this setup you could share? I am thinking of doing similar myself whilst I decide on the correct bar/stem combo
Roel W
by Roel W
Edit: Post removed; Made a mistake assuming it was a Scott bike.
eins4eins
by eins4eins
Scott Bar on a Bianchi? ;)
stevec1975
by stevec1975
Yeah, not a Scott bar or bike, wrong chat perchance?!
vanitypl
by vanitypl
Neillp wrote:
Wed Mar 15, 2023 6:18 pm
I don't have access to the bike at the moment, but there was another user in this thread who's running something similar. I can't find their exact post, but I did save their gallery for inspiration when I was doing mine https://imgur.com/a/UbZqJES
In this case they 3D printed a headset cover, but the stock headset cover/bottom spacer does the trick as well.
How clean it looks will also depend on the groupset you're running - I've got mechanical ultegra (a bit of a service nightmare for this bike) and the 2 extra cables do make it look a little messier compared to the di2 here. If you still wanted a pic of my setup I can grab one as soon as the bike's back in my hands.
Ytse
by Ytse
Is it possible to run the Addict RC with 140mm brake rotors? How?
2020 Scott Addict RC / 2021 Trek Emonda SLR / 2023 Specialized Tarmac SL8
pmprego
by pmprego
Ytse wrote:
Thu Mar 16, 2023 11:41 pm
Rear only.
Ytse
by Ytse
pmprego wrote:
Thu Mar 16, 2023 11:57 pm
Rear only.
Thanks!
wheelie
by wheelie
I wonder if Schwalbe G-One RS 35 mm tyres, mounted on stock Syncros Capital 1.0 35 wheels ( 21mm inner width) will fit the L size RC10 frame? Anyone tried? Tnx!
2020 Cervelo Aspero Apex 1 Mid Olive/Dune ----> Burgundy/Dark Orange
2022 Scott Addict RC10
pmprego
by pmprego
wheelie wrote:
Sat Mar 18, 2023 10:50 pm
I wonder if Schwalbe G-One RS 35 mm tyres, mounted on stock Syncros Capital 1.0 35 wheels will fit the L size RC10 frame? Anyone tried?
I highly truly doubt it. Didn't try it. But a 30c tire growing up to 32mm.is already a too tight fit imo
wheelie
by wheelie
I tried 32 mm GP5000 TL on these wheels and there was still a space left
ddddd1
by ddddd1
I have been running 32mm GP5000 TL (32mm real width) in the rear as well, but that is absolute limit. Any more and there will not be enough space to clear the gravel on the tyre. Btw, the above mentioned bike with the 3D printed spacer is mine. In case anybody is interested in such solution, just drop me an email and I'll send you the 3D model.
Enid: Scott Addict RC Ultimate Team Ed - 7.2 kg (in. pedals and bottle cages)
Reds
by Reds
stevec1975 wrote:
Mon Feb 20, 2023 11:49 am
Finally finished building and did the first ride yesterday, love it!
Hello,
I'am looking for a SRAM Quarq power meter.
I found a Dfour spider with Quarq DUB crank arms with needed bottom bracket SRAM DUB.
I understand that you have not exactly this setting, you use a GXP crank arms with bottom bracket PressFit GXP, right ?
Does the DUB setting is compatible with our bike ?
Did you tried to fit a chainring R8000 on the Dfour spider ?
Thanks
ddddd1
by ddddd1
@Reds Yes, DUB spindle is compatible, but the bottom bracket bearings have to be smaller and therefore will last shorter.
R8000 and R9100 are functionally the same in every aspect, the chainrings will fit but the colour might not match.
Reds
by Reds
I don't know which bottom bracket DUB I need for Scott RC, do you have a part number ?
Then, I could adapt the Quarq DUB crank arms.
