Dura-Ace R9200
bmrk
by bmrk
LedZeppelin007 wrote:
Tue May 02, 2023 3:30 pm
Spent a bunch of time last night trying to get the shifting to an acceptable level. Started by making sure the hanger was straight (it was). Got the chain to the right size. Set the b-limit as close to spec as possible.
Still having issues with a couple of cogs making noise (4th and 5th and, sometimes 7th). With the 11-34, also had an issue where it was having difficulty shifting from 12th to 11th.
Is it fair to assume that my cassettes are bad? What else is there to do?
I would certainly order up an R9200 11-34t if it was guaranteed to work at this point as that would be cheaper than taking it to the bike shop having them diagnose it and submit a warranty claim to Shimano.
As long as it shifts well try to ignore the clicking on the 5th cog and eventually it will go away. On both my ultegra and da 12 speed cassettes the clicking on the 5th cog disappeared after a good few hundreds of kms perhaps close to 1k.
bowtieguy
by bowtieguy
The clicking is so annoying. I've spent a lot of time trying to chase it down. As a couple of other people noted in other threads online, a KMC DLC 12 chain does seem to have helped this symptom considerably--not gone entirely, but a noticeable improvement. No, I don't work for KMC and no, I'm not happy about having to spend money on a boutique chain after spending lots of money already on a brand new bike and groupset. I'm hesitant to throw good money after bad by buying a third cassette to try, but I suppose I will eventually get to that point if I don't sell this groupset to revert to 11-speed before that. The noisy 21T gear is one thing, but I just don't find the rear shifting on the 12-speed as quiet and reliable as 11-speed. Things I've tried that HAVEN'T helped with the ticking/clicking:
* two different cassettes
* experimented with different torque settings on the cassette (tried under torqued, torqued to spec and over torqued)
* double checked spacer placement
* b-screw setting checked with Shimano tool several times
* indexing the bike in several different configurations (exactly to Shimano instructions, then biasing inboard and outboard)
* replacing rear mech hanger
milanv
by milanv
So, again. :wink:
milanv wrote:
Sun Mar 05, 2023 7:58 pm
Maddie wrote:
Sun Mar 05, 2023 3:23 pm
Remove the glued ring that is sitting behind the cassette:
viewtopic.php?f=3&t=168810
:thumbup:
milanv wrote:
Fri Jan 20, 2023 8:22 am
From this thread viewtopic.php?t=156208
milanv wrote:
Sun Nov 27, 2022 12:35 pm
So, several hours of mechanic job and here we go with the update of clicking a wobbling problem of my Ultegra cassettes on new wheelset. :wink: :smartass:
1. New cassette on the freehub wobbles and the 5th cog clicking problem remains. :|
2. Old cassette on the freehub wobbles less but still wobbles, the 5th cog clicking problem remains. :|
3. Old cassette without the glued ring and the special Shimano 1mm ring behind, it wobbles more than with the glued ring :x + it does not have ideal freehub movement when tightening to the correct tighten moment. :unbelievable: :x
4. Old cassette without the glued ring, voilà, it does not wobble. :) :beerchug: + the 5th cog clicking problem is lesser, it remains, but it is very very tiny.
:beerchug: I had to give it a minor adjustment in eTube Shimano app, but it is many times better and I can live with it at the moment.
I estimate that several people will not spot it.
:beerchug:
pdlpsher1
by pdlpsher1
bowtieguy wrote:
Tue May 02, 2023 6:45 pm
Replacing the hanger doesn't guarantee a straight hanger. A HAG (hanger alignment gauge) will ensure a straight hanger. It's a good investment.
The 12-speed is more finicky to setup than a 11-speed due to the closer spacing. You need patience and some small experimentations.
satanas
by satanas
One *always* needs to check the hanger is straight, new or old; they're easy to bend out of shape. Oftentimes hangers on new bikes need adjusting during assembly...
kode54
by kode54
This is true. A slight bend from shipping or even packing into a bike box. New or old.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
Nickldn
by Nickldn
I have put on a brand new original hanger on my bike (not a SL7) fully expecting to be straight.
When I checked with a park tool dag-2.2 to my surprise it really wasn't anywhere near straight.
So yes, would recommend checking the RD hanger, new or old, with a proper alignment tool.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
Maddie
by Maddie
I bought an Ultegra 12s 11-34 cassette somewhere around December 21 that I used for a couple hundred km. It made that known clicking sound (I removed the ring behind the cassette already). I switched to a Dura Ace cassette that remains silent still. I discovered the Ultegra cassette recently and decided to send it back to bike24 and see what happens. My experience with them is that they replace parts in almost all cases. But in this case, they decided to refund me and not send a replacement cassette. Make of that what you will.
Aesch
by Aesch
bmrk wrote:
Tue May 02, 2023 3:42 pm
This sounds like it's caused by something lifting or touching the chain which wears away with time.
Im experiencing the same issue on the 21 cog. Other than that I love the rim brake groupset on my madone!
ODC
by ODC
Some other people have a clicking chain noise when back paddling (in a work stand for example)? You can also feel the click. Dura Ace 12 speed (new groupset).
Normal/forward paddling and there is no noise.
BigBoyND
by BigBoyND
That's normal when slightly cross chained. There's no derailleur at the top of the cassette, so the chain tracks a straight line from the chainrings.
Co0kieMonster
by Co0kieMonster
Hey folks,
I'm bothered by an annoying issue and too stupid to handle it, so maybe you can help out: I ride the Ostro in 52 with an Ultegra Di2 12-speed / Dura Ace Stages powermeter crankset. The micro adjustment of the front derailleur is already maxed out to -19, but distance of the outer plate to the chain (big chainring, smallest cog) is still clearly more than 1 mm. What mistake on my part am I overlooking? Any ideas?
K4m1k4z3
by K4m1k4z3
Co0kieMonster wrote:
Thu Jun 01, 2023 1:08 am
Hey folks,
What helped me on my SL7 Expert was to setup the FD again from scratch. I set the height at 1.5~2 mm above the big chainring and then REALLY angled the tail of the FD inwards. Almost excessively. Then I straightened it and brought it in line with the big chainring using the support bolt. This creates tension on the whole FD and FD support assembly making it sturdy. After that I could set my micro adjustment properly.
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
jayjay
by jayjay
To the people who switched from 11 to 12-speed:
Do you feel the extra 5mm reach from the new STI?
Have you changed your stem/bar because of that?
Spinnekop
by Spinnekop
jayjay wrote:
Fri Jun 02, 2023 7:10 am
No.
If I did not read this here right now, I would not have known. :D
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
