Dura-Ace R9200
I have one incoming.GONE4ARIDE wrote: ↑Tue Feb 21, 2023 1:12 amStages has a new dual-sided DA unit out that has tested very well. Here is a link to GP Lama's review:BdaGhisallo wrote: ↑Mon Feb 20, 2023 11:25 pmThey're probably ditching them in races too like using a non drive Stages and just going with that alone.henau212 wrote: ↑Mon Feb 20, 2023 7:36 pmYikes.. Shimano sponsored teams swapping to non Shimano PMs during training?BdaGhisallo wrote: ↑Mon Feb 20, 2023 7:00 pmOuch!
Shimano R9200P Power Meter In-Depth Review: Astonishingly Inaccurate
https://www.dcrainmaker.com/2023/02/shi ... 7vYCazjyIU
https://youtu.be/H1YxXidWZc4
I’ve owned one. It works.BdaGhisallo wrote:I have one incoming.GONE4ARIDE wrote: ↑Tue Feb 21, 2023 1:12 amStages has a new dual-sided DA unit out that has tested very well. Here is a link to GP Lama's review:BdaGhisallo wrote: ↑Mon Feb 20, 2023 11:25 pmThey're probably ditching them in races too like using a non drive Stages and just going with that alone.
LedZeppelin007 wrote: ↑Tue Feb 21, 2023 8:22 pmI’ve owned one. It works.BdaGhisallo wrote:I have one incoming.GONE4ARIDE wrote: ↑Tue Feb 21, 2023 1:12 amStages has a new dual-sided DA unit out that has tested very well. Here is a link to GP Lama's review:BdaGhisallo wrote: ↑Mon Feb 20, 2023 11:25 pm
Good to hear. I don't ask much of a powermeter but basic accuracy is needed.
Good to know. Thanks. It'll likely be the way I go when I build up a DA12 bike.LedZeppelin007 wrote: ↑Tue Feb 21, 2023 8:22 pmI’ve owned one. It works.BdaGhisallo wrote:I have one incoming.GONE4ARIDE wrote: ↑Tue Feb 21, 2023 1:12 amStages has a new dual-sided DA unit out that has tested very well. Here is a link to GP Lama's review:BdaGhisallo wrote: ↑Mon Feb 20, 2023 11:25 pm
- ultimobici
- in the industry
- Contact:
Very doubtful. Why?eins4eins wrote:Is there a possibility to run a shimano 12x drivetrain with a cassette with 10 speed cog?
- ultimobici
- in the industry
- Contact:
Aside from the issue of whether a 50X10 gear is necesssary, where are you intending to get a 10-33 10 speed cassette? As far as I can tell, there isn't one available!
Or do you mean a 10T top sprocket non-Sram cassette?
yes, i meant a 10t sprocket for 12sp. Currently i'm running 52/39 with 11-32 cassette and i can ride almost everything in the big ring. With a slightly smaller big chainring i could stay in the big ring probably 99,5% of the time. 50T with 11-32 doesn't work for me.
- ultimobici
- in the industry
- Contact:
I have both 11T & 10T cassettes, albeit on different systems. On a gravel bike the 10T isn't that annoying because the tyres are more of an issue than the feel of the 10T. When I drop a set of slick 700C tyres into the bike it highlights just how awfully inefficient the 10T is.eins4eins wrote: ↑Wed Feb 22, 2023 10:32 amyes, i meant a 10t sprocket for 12sp. Currently i'm running 52/39 with 11-32 cassette and i can ride almost everything in the big ring. With a slightly smaller big chainring i could stay in the big ring probably 99,5% of the time. 50T with 11-32 doesn't work for me.
Why not look at 52/36 with an 11-34? You'll gain an extra gear in the 52 as well as a slightly wider range to boot.
http://www.gear-calculator.com
For those of us who are stuck with R9100P and R9200P, is there any recourse? I chatted with Canyon and they offered $50 to take it to a local Shimano tech to check out. For now, it’s just kind of a useless piece of gear on my bike and I’m running Rally pedals and dual recording.
Do you notice large discrepancies in numbers between the 2? I'm just wondering about real world use as compared to the minute analysis by DC Rainmaker, etc.LedZeppelin007 wrote: ↑Wed Feb 22, 2023 3:12 pmFor those of us who are stuck with R9100P and R9200P, is there any recourse? I chatted with Canyon and they offered $50 to take it to a local Shimano tech to check out. For now, it’s just kind of a useless piece of gear on my bike and I’m running Rally pedals and dual recording.
Why not just sell the Powermeter, buy a standard spider and use the Rally? The did not fix the old and my bet is that they are not going fix the new one..LedZeppelin007 wrote: ↑Wed Feb 22, 2023 3:12 pmFor those of us who are stuck with R9100P and R9200P, is there any recourse? I chatted with Canyon and they offered $50 to take it to a local Shimano tech to check out. For now, it’s just kind of a useless piece of gear on my bike and I’m running Rally pedals and dual recording.
I love the SW-R600 satellite shifter on my 9150 setup - though it was a 9070 generation product.
Is there anyway that this switch can be spliced into a 9250 DI2 system?
