The ideal bar tape (which, when and why)?
- wheelsONfire
I like Sram Super Suede. It's quite easy to undo (if needed) and re-wrap.
Zipp CX tape have some gel and it cracks ( i noted while re-wrapping).
Sram RED tape tear if you re-wrap it.
Kind of like the Sram/ Zipp tapes as they match the hoods texture and color tone.
I don't need a high damping tape, i use MAP gloves and they are darn excellent
Bikes:
Open *UP* (2016.04.14)
The SRAM super suede looks like the old Specialized Roubaix tape.wheelsONfire wrote: ↑Sun Jul 02, 2023 10:37 pmI like Sram Super Suede. It's quite easy to undo (if needed) and re-wrap.
- wheelsONfire
Visually they look alike. But there's no gel in Super suede
Bikes:
Got a few different suggestions, may as well try a few and see how I go. Thanks all!
Ridley Helium SLX - RIP https://weightweenies.starbike.com/for ... lit=ridley
Scott Foil - current viewtopic.php?f=10&t=173046&p=1813155#p1813155
+1CyclingGiraffe wrote: ↑Sun Feb 14, 2021 5:57 pmWent back to plain old Deda Elementi "Logo" tape after messing around a bit with other stuff (Fizik, Lizardskins, etc.). It's cheap, light, easy to wrap, grips well in dry or wet conditions, and is durable and easy to clean.
It stands out in the sea of many more expensive and heavier tapes
Was there gel in Roubaix tape? I used it for a number of years and I don't recall there being any gel in it. It was a relatively thin tape that I used to double wrap to get a thicker bar to hold.wheelsONfire wrote: ↑Mon Jul 03, 2023 12:18 amVisually they look alike. But there's no gel in Super suede
- wheelsONfire
Don't know, i don't use Specialized products.BdaGhisallo wrote: ↑Mon Jul 03, 2023 10:29 amWas there gel in Roubaix tape? I used it for a number of years and I don't recall there being any gel in it. It was a relatively thin tape that I used to double wrap to get a thicker bar to hold.wheelsONfire wrote: ↑Mon Jul 03, 2023 12:18 amVisually they look alike. But there's no gel in Super suede
But there's some info
Elastomer gel backing provides additional comfort and vibration damping
Bikes:
Oh, right. That's the thin bit of gel that many manufacturers are using to replace the old strip of tape on the back of bar tapes. Spec introduced that change after I stopped using Roubaix tape. It had no backing tape back when I was using it.wheelsONfire wrote: ↑Mon Jul 03, 2023 11:12 amDon't know, i don't use Specialized products.BdaGhisallo wrote: ↑Mon Jul 03, 2023 10:29 amWas there gel in Roubaix tape? I used it for a number of years and I don't recall there being any gel in it. It was a relatively thin tape that I used to double wrap to get a thicker bar to hold.wheelsONfire wrote: ↑Mon Jul 03, 2023 12:18 amVisually they look alike. But there's no gel in Super suede
I believe Silca uses PEBAX on their tapes? Ive always wanted to try
I love Lizardskins, have the 3.2mm on my gravel bike
If you're in the EU another good option according to the TOUR magazine test would be the Rose Soft AR 2,5. Best price performance ratio in the test.
Road
Cube Agree C:62 SLT 2021 (frame+fork) DA 9270 6.9x kg - ride-ready 7.25 kg w/pedals, cages, sensors, Wahoo mount
Gravel
Velobuild GF-002 Force AXS 7.5 kg, ride-ready 7.775 kg w/200 ml Stan‘s, pedals, cages, sensors, Wahoo/Cateye mounts
Gravel
tesa tape is the GOAT but it wears badly, better to save for special occassions
i've been using Newbaum's black which are pretty light and wraps very thin, only thing is that the black dye leaks/wears quickly and turns brown with sun exposure, hand sweat, etc
