CAAD13
CampagYOLO
by CampagYOLO
I used the KP253 and found it fitted fine. I did have to add a 2mm spacer between the cover and the stem which meant there was enough preload to prevent any play as I found the same thing as yourself without a spacer despite Cannondale's instructions stating that there is no need for a spacer.
Kvh87
by Kvh87
Interesting. Could it be that the part I have might actually be something else? I've measured the diameter at 45,2mm and the height at only 4mm. Quite a bit different to the 46mm and 5mm that is mentioned everywhere.
flemingcool
by flemingcool
Kvh87 wrote:
Tue May 09, 2023 2:52 pm
This is the same as what I got. KP253, external diameter seems too small. It doesn't even cover the top of the head tube, leaving unpainted metal visible.
tomh79
by tomh79
Has anybody heard any rumours about a CAAD14 or CAAD13 upgrade? Since we have a new Supersix now with BSA BB...
romanmoser
by romanmoser
i for one they let the caad die
the caad13 and allez sprint last gen are very overpriced alu cans , with non compliant qc , lot of troubles etc
not worth it
buy less expensive brands carbon fibers offerings , used ti or whtvr
fizzaz
by fizzaz
The true successor to both is the new Emonda ALR. It's everything the caad13 should have been after the 12
C36
by C36
romanmoser wrote:i for one they let the caad die
not worth it
Overpriced? Sub 700€ for a frame that score the max on all stiffness measures and even great on confort?
For a guy/girl racing on circuits it’s a fantastic frame. Last time I saw a Cannondale with a BB problem that was 3 years ago…
Aesch
by Aesch
Where can you find the frame at that price?
C36
by C36
That was at my LBS last may.
Was a rim brake size 51
Aesch
by Aesch
Impressive! I'd buy one at that price right away too
PUNlSHER
by PUNlSHER
romanmoser wrote:
Mon Jul 24, 2023 3:17 pm
not worth it
I've never heard more rubbish about caad
S6 EVO3 - 6380g CAAD13 - 6626g TOPSTONE Al - 8195g
Gaz9
by Gaz9
not worth it
Absolute nonsense! Both much better option than low end carbon
ganski
by ganski
Has anyone found a replacement carbon cradle for the caad13 seatpost? Looking to make it a little lighter.
PUNlSHER
by PUNlSHER
ganski wrote:
Fri Aug 11, 2023 10:34 pm
https://a.aliexpress.com/_ExzPL1D (30g lighter than stock) :thumbup:
ganski
by ganski
Thanks, I have an elita one in 27.2 and 31.6 as well as a hylix 25.4 off my caad12, none of the carbon cradles matched and left a gap in U shaped dish. Also is there a nailed down weight on the CAAD13 disc frameset. I'm thinking about tearing mine down and having the painted removed. Im hesitant it won't be anywhere close to my 12 around 6.35kg. If I could get in under 6.8kg that would be fine.
