Orbea Orca 2020
Eterna7m
by Eterna7m
mariosimas wrote:
Sun Nov 07, 2021 7:35 pm
https://www.orbea.com/es-es/myo/step-customization/
click on "Paleta de colores"
than you can choose between "brillo" and mate"
Thanks, but when you click carbon raw it only applies a black.
mariosimas
by mariosimas
you cannot see it on the complete bike.
only on the small squares in "paleta de colores".
but its better than noting
powpow
by powpow
Hi. What is the approximate weight of the size 53 with Red Axs group and the stock Vision 40 wheels? Thanks.
mrlobber
by mrlobber
Around 7.5 without pedals.
Frameset including BB / headset and stem + seatpost together is a touch above 2kg. Add all else on top.
KalleWirsch
by KalleWirsch
Hi all,
I bought a brand new Orbea Orca (OMX) with Shimano Ultegra Di2 12 speed and have two questions:
1.
My seatpost clamp doesn´t hold the saddle when clamped with 9NM. There seems to be play into the seatpost head. The mechanism inside has play. It´s not 100% tight.
My dealer said that all of his OMX do have this issue. He clamped the seat with 14NM, which is far more than the official limit. Now, it´s tight. Is this true? Anyone with the same problem?
When I look at the clamp mechanism, I can imagine that the tolerance is just not good. The mechanism has to clamp the saddle rails AND the vertically adjustment at the same time. If there is only little play and both is not 100% the same, then it can´t work. Strange mechanism.
2.
I´ve bought the version without power meter and would like to add a single sided left crank power meter.
Both tests if the fit from Stages and 4iiii fail (AAA battery and 10 Allen key). Too less space.
I wonder if one of them will fit anyhow, because they sell it as an option from the factory, as well.
Thank you!
KalleWirsch
by KalleWirsch
Hello,
me again.
with regards to point #2 above: I can say that a stages left side powermeter fits perfectly on a size 55 OMX frame with Ultegra 12speed 172,5mm crank. Enough space to the frame.
3. What is your experience with the paint quality with regards to scratches? My paint seems to be very sensitive to scratches. Clear coating on the glossy parts gets scratches when touching it by hand or a dry micro fiber towell.
mariosimas
by mariosimas
Here his my Orca 2022 (mettalic silver + mettalic jade green)
with Ultegra Di2 12V
Wheels : hubs dt 180, yoeleo tubular rims (Fr: 38 mm; Rr: 50 mm)
Weight: 7,42 kg
Koev
by Koev
Hello!
Anyone upgraded their 2020 version (or later) from 11 speed to 12speed?
I'm looking to go from mech Ultegra 11s (r8050) to di2 Ultegra 12 (r8170) but orbea'S blue paper says it is not compatible?
Are their differences in the newer frames?
Thanks.
Dutch
Orbea Orca OMX 2020
Startersbike: Cube Attain 2017 (mounted@ Tacx Neo2)
mrlobber
by mrlobber
In which place exactly does it say so? There aren't any specific details in the frame which would prohibit using electronic Shimano groupset :noidea:
TLN
by TLN
They have some Orca with 12sp available on a website. I don't see a reason why it wouldn't be compatible.
His: Orbea Orca OMX
Koev
by Koev
It says so in the blue paper (https://orbea.dash.app/browse/fe00e6eb- ... ea-manuals).
Schermafbeelding 2023-06-01 101034.png (6.51 KiB) Viewed 1342 times
I mailed Orbea and they confirmed that this is correct, however I ignored their advice and started my rebuild. Everything fits so far!
Thanks for the replies.
Dutch
Orbea Orca OMX 2020
lazpujilaksono
by lazpujilaksono
Has anyone installed a 1x groupset on their Orbea orca OMR frame? Would it be compatible? particularly a sram mullet axs. Thank you.
Jonolsson
by Jonolsson
Tour de France femmes...
Enviado desde mi 2201123G mediante Tapatalk
Ritxis
by Ritxis
Do the frame seat stays return to a more traditional position?............
BernieMoves
by BernieMoves
Janboo wrote:
Sun Mar 21, 2021 10:29 am
As for the size of the Orca, it will be a 53. I'm 181cm tall with inseam 83cm. (32.7 inch). Tried a 51 (too small) and a 55 (felt too big) so ended with a 53.
I can confirm that with similar measurements (182 height, 84 inseam) the Orca OMR in 55 felt too stretched out for me, so I'm happily riding a 53.
