HBike wrote: ↑Fri May 19, 2023 8:35 am
Almost every bike is stronger at common lower yaw angles (with differences there not that huge). Nothing special. Whether the S5 was especially optimised for this set of yaw angles - I don't know. Main differentiation of the Tour results is based on differences at larger yaw angles. And here design goals come into play (see below). Similar with deeper wheels (look at the spread where strong differences occur north of 15 degrees yaw).
From an article at Cyclist:
Trek: ‘In the real world 2.5° to 12.5° are the most prevalent yaw angles riders encounter.’
Yu at Specialized adds, ‘For an average cyclist, unless you’re riding in extremely windy conditions, the typical angles are less than 10°.’
This slight difference in results is why one aero bike doesn’t look identical to another. Specialized designed the Venge ViAS based on its vision of the perfect range of yaw, while Trek designed the Madone to fit a different range.
So it seems that if you’re Peter Sagan, driving the peloton along at 50kmh, you want a bike optimised to deal with yaw angles of around 3°-7°, while the rest of us want a bike designed to tackle yaws of up to 10°-12°.
‘If you look at a WorldTour sprinter coming off a wheel in the last 200m of a race, the effective yaw is extraordinarily low – close to 0°. That’s because they’re going really fast, more than 60kmh, and finishing straights are typically well shielded by barriers and crowds, which serve to block any crosswinds.
‘On the other hand, if you go to the Kona Ironman World Championships, they ride up the Hawaiian coast, with the wind blowing in across the water, so for an age-grouper at Kona the effective yaw angles hit up to the 15° range if it’s gusting. Pros will be going a little bit faster, so they’ll see yaw angles of up to 10° or so – maybe low teens,’ says Yu.
