Darimo Carbon components, when Spain beats Germany
Does Darimo make stem adaptor for Colnago C68/V4RS? My friend wants a Nexum integrated
Sizing question for the seat post. Based on the pictures, a 350mm should be fine right? Specialized says 75mm minimum insertion for their seatpost. Using the bolt for a starting point, the 350mm would give me ~105-110mm, using the rails, it's probably ~95-100mm.
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
LanceLegstrong wrote: ↑Fri Jul 21, 2023 10:52 amSizing question for the seat post. Based on the pictures, a 350mm should be fine right? Specialized says 75mm minimum insertion for their seatpost. Using the bolt for a starting point, the 350mm would give me ~105-110mm, using the rails, it's probably ~95-100mm.
This set of instructions apply to the SL7 darimo
Plus the instruct from darimo to measure for seatpost length
S Works SL8 54cm 5.94kgs
Winspace SLC M Ultegra R8150 no idea of kgs
Yes the maximum length out of the the frame for a 350mm darimo seatpost is 265mm yours looks like 245mm or 24.5cm from the photo.
So yes to 350mm
Was Trentin using a Darimo post today? If so, what has happened here?
Looks just like mine, with the front bar broken in half. Perhaps I put too much torque (4NM)? I had to ride the bike without a saddle for 7km to home, all uphill. I loosened the one on my other bike and thus far no saddle slip. Keeping fingers crossed. Darimo has sent me a replacement.
Question for owners of a T1 classic seatpost: what’s the horizontal distance between the top rail clamps (outside to outside)? Is this distance larger for D-shaped T1 aero posts?
Trying to figure out if I can use the inline version of this with a Selle Italia saddle with a narrow clamping range.
My Darimo T2 already came with Titanium bolts
Not sure if this helps but on my Cervelo R5 D shaped post it's 54mm.ry5n wrote:Question for owners of a T1 classic seatpost: what’s the horizontal distance between the top rail clamps (outside to outside)? Is this distance larger for D-shaped T1 aero posts?
What Garmin varia mount you got there?Aryeh wrote: ↑Tue Aug 15, 2023 3:38 amNot sure if this helps but on my Cervelo R5 D shaped post it's 54mm.ry5n wrote:Question for owners of a T1 classic seatpost: what’s the horizontal distance between the top rail clamps (outside to outside)? Is this distance larger for D-shaped T1 aero posts?
That does help, thanks! I was hoping it was less, but it's very close to what I expected.
