DieselCondor
by DieselCondor on Fri Mar 22, 2024 9:55 am
kode54 wrote: ↑Fri Mar 08, 2024 11:02 am
snaxez wrote:What would be best organic pads to use with BR-R9270 and Hope RX CL rotors?
Options:
SHIMANO K05Ti-RX ~13€ pair
SHIMANO L05A-RF ~13€ pair
Galfer FD496 G1455 ~15€ pair
TRICKSTUFF 270 STANDARD ~18€ pair
SWISSSTOP 34 RS pads for ~20€ pair
TRICKSTUFF 270 POWER pads for ~23€ pair
Or is there something good, that I have missed?
Should I just go with cheaper Shimano organics, or pay a bit more for swissstop or trickstuff?
I couldn’t find Swissstop 34RS anywhere and still using Shimano L05A on the Hope RX rotors with good bite.
I'm currently using Hope RX, with Shimano B05S- they are excellent.
I was using swissstop e which were decent, but was very disappointed when I tried the RS version.
kode54
by kode54 on Fri Mar 22, 2024 12:09 pm
DieselCondor wrote: ↑Fri Mar 22, 2024 9:55 am
Options:
Is the Shimano B05S resin pad material same as the L05A? Its about 1/3 the price...and do they fit in DA 12-speed calipers?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
1llum4
by 1llum4 on Sun Mar 24, 2024 1:09 am
kode54 wrote: ↑Fri Mar 22, 2024 12:09 pm
B03S and B05S pads do not fit in 105/Ult/D-A Caliper, you need either L or K series pads.
kode54
by kode54 on Sun Mar 24, 2024 12:01 pm
1llum4 wrote:kode54 wrote: ↑Fri Mar 22, 2024 12:09 pm
Thx.
- Factor LS Disc
QuackMD
by QuackMD on Tue Apr 02, 2024 5:49 am
Feddesman wrote: ↑Mon Apr 01, 2024 5:22 pm
I'm looking for discs for long descents for red Axs. Paceline and centerline will fade eventually. Does anyone have a good suggestion?Maybe other brake pads?
Might I recommend the rotors from brake stuff (
https://brake-stuff.de/en/brake-discs/)? Specifically their XT and punch design. They come in a variety of widths (1.8-2.2 mm) and are very resistant to fading and warping. They are heavier thatn most of the rotors out there, but for the use case you're describing, it seems like a reasonable compromise. I'm personally using the their XT rotors and haven't had a problem yet.
Lelandjt
by Lelandjt on Tue Apr 02, 2024 12:27 pm
If your fork can take a 180 rotor, use one. No road frames can take a 180, do they? Going up in size makes the biggest difference in how much heat a rotor can take and how fast it sheds heat. For sure, avoid resin or organic pads.
CampagYOLO
by CampagYOLO on Tue Apr 02, 2024 1:01 pm
Lelandjt wrote: ↑Tue Apr 02, 2024 12:27 pm
Only Merida off the top of my head which Mohoric used to his advantage to win Milan San-Remo along with that dropper post.
jlok
by jlok on Tue Apr 02, 2024 2:38 pm
Use 2.0 thickness rotors like SRAM HS and Magura Storm HC.
