Question for Enve SES Aero Road Bar owners
endershan
by endershan
bambinhyung wrote:
endershan wrote:I use this stem mount from Fouriers.
http://www.fouriers-bike.com/en/pro.php ... cid=28&f=5
Looks really good! Do you think that mount would work with an Enve stem?
It will work fine with Enve stem, but what @danridesbikes proposed above is a much neater solution! With Fouriers mount you can only have the computer way above the handlebar, Enve gives you more option.
bambinhyung
by bambinhyung
danridesbikes wrote:do you have an Enve stem?
http://www.elitecustom.sg/products/quad ... 2513829827
Yes I do. Thanks for the link!
But they're unfortunately sold out... :(
Do you know of any other mounts like that out there? That are compatible with Enve stems?
danridesbikes
by danridesbikes
all they have done is fix one of these to the underside of the ENVE mount
you just need to drill and tap the cross beam underneath, and they say they used epoxy in there as well, i guess as a belt and braces approach
http://www.twohubs.com/PortalDocs/170/E ... unt-04.jpg
http://www.tweekscycles.com/Product.do? ... oCi_Hw_wcB
bambinhyung
by bambinhyung
Thanks a lot for the tips guys!
So here the update for my setup with my front light attached to the custom ENVE computer mount.
ENVE Custom Garmin & GoPro Mount: http://www.elitecustom.sg/products/quad ... 2513829827 (Thanks for the link danridesbikes)
Cateye Light GoPro Mount: http://www.rec-mounts.com/products/adapter/gp-cathl2/
Fixie82
by Fixie82
Realise this was mostly around computer and light mounts but wanted to ask if anyone here is running the Enve SES Aero bars with a wide clamp stem such as the Pro Sprint? I've seen a few set ups with a Zipp Sprint stem but not the Pro.
I'm keen on trying out the Enve bars but not so keen if they don't fit. I have a computer mount that attaches via the stem bolts so space to run accessories on the bar is not an issue.
Would be grateful if anyone can chime in with some information.
Bullet
by Bullet
Ive just ordered this one, hopefully it works out well.
https://www.rec-mounts.com/products/enve/garmin-combo/
hongsj
by hongsj
If you have a garmin edge 1000, use envy computer mount V2.
Kurt1980
by Kurt1980
Anyone have a lead for a Garmin mount for the bar with a Ritchey Chicane B2 stem? The bolts are on a 45 degree angle, and thread in from the back. Not a lot of real estate at the 31.8mm section of the bar.
Photos attached. TIA!
Kurt1980
by Kurt1980
Follow up question...
Has anyone run these bars with AXS rim brake shifters with internal housing through the bar? AXS shifters have only 1 dedicated guide for the housing in the body of the hood. This guide leads to the inside of the bar. It's going to be a very tight fit for the housing to get around the corner and travel the length of the bar.
SRAM Red 22 had 2 options, inside and outside of the bar.
Photos below for reference.
Edit - added a 3rd picture.
VG2
by VG2
Kurt1980 wrote:
Wed Apr 26, 2023 2:19 pm
Hi, I have exactly the same problem. Have you found a solution meanwhile? Thanks a lot
Regards
Vin
Kurt1980
by Kurt1980
:welcome:
VG2 wrote:
Fri Jun 21, 2024 9:33 am
Regards
Vin
No such luck unfortunately. I ended up sending the Ritchey back and now run a Newmen stem with 4 bolt face plate.
Kurt
