201x Specialized Allez Sprint DSW and Gen2
jorryt
by jorryt
jorryt wrote:
Fri Mar 13, 2020 10:55 am
Nice! Here is mine. Same color different braking system.Image
Sadly my bike was stolen two weeks ago in Limburg the Netherlands....
So if any of you notice a great deal on an Allez Sprint with 38cm handlebars, negative stem, powermeter, FFWD wheels, Pro stealth saddle and brand new cassette/chain it was mine :?
Ferry
by Ferry
Sad to hear that. I am also in Limburg, I will keep my eyes open.
joesch
by joesch
joesch wrote:
Tue May 09, 2023 12:43 pm
I am in the exact same situation - initially, I was told by my LBS that the new framesets would arrive in May - which is now and not new ETA unfortunately.
The last day of May is here and the delivery date seems to have been removed from the systems - in other words: no ETA and/or visibility on when these frames will become available.
Aside from the frustration of not being able to build up my frame, I wonder what the root causes are that none of the framesets seem to be available anywhere other than the remainders from previous years, and what this means for Specialized's cash flow.
Dadbodcyclist
by Dadbodcyclist
:beerchug:
mathieurrr
by mathieurrr
😍 2 questions for you.
Is that the standard mount for the varia? I was wondering if it would work with the venue seatpost.
Is it fully internal? Usually you always see the front brake line running down but I see nothing.
Dadbodcyclist
by Dadbodcyclist
You have a good eye mathieur
The varia mount adapter came with the varia itself and the cables are fully internal. I just finished the build other day. Might be a first for the og allez series. I have a before and after for you
mathieurrr
by mathieurrr
That's amazing! I have a similar Allez and my only real reason to "upgrade" was for the clean aesthetic of internal cabling. Now I know I won't have too. I'll also be ordering the varia as well now that I know that.
Dadbodcyclist
by Dadbodcyclist
Ride the sl7. Marry the allez sprint. Its a keeper.
If you need help on how to internally route then feel free to reach out
stefanoo
by stefanoo
Just finished :beerchug:
joesch
by joesch
joesch wrote:
Wed May 31, 2023 8:15 am
New revised date for the 2023 frameset (size 56) has been updated to w/c July 17th. :|
Nick38
by Nick38
stefanoo wrote:
Tue Jun 06, 2023 8:42 am
Gorgeous. Love that colour, enjoy :thumbup:
eli76141
by eli76141
Dadbodcyclist wrote:
Sun Jun 04, 2023 10:02 pm
The varia mount adapter came with the varia itself and the cables are fully internal. I just finished the build other day. Might be a first for the og allez series. I have a before and after for youIMG_20230306_141748.jpgIMG_20230306_141748.jpg
How did you hide the brake cables inside the frame? Is the frame made for internal routing?
GGDoomed
by GGDoomed
Is that that the Down Under paint job? Looks really slick
FINISHED : Cube Litening C:68X S
stefanoo
by stefanoo
GGDoomed wrote:
Thu Jun 08, 2023 11:25 am
That's right, it's the 2020 TDU Edition frame. It's my first Allez. I can't believe how fast this thing is :unbelievable:
Dadbodcyclist
by Dadbodcyclist
eli76141 wrote:
Thu Jun 08, 2023 11:20 am
Not made for internal routing. You have to drill a hole in the steerer big enough for the hydraulic hose and di2 cable. Then you need to find a steerer plug that's capable of letting 2 hydraulic hoses and a di2 cable through. The rest is in the handlebar. You need a handlebar that routes through the top section of the stem area into the steerer tube. There are only a handful on the market that can do this. With this you can essentially convert any bike into fully integrated
