Yeah, that's pretty much how I would go about it. A good wet sand with 400/600 grit, clean it real good and mask it off, then you're set for primer.BikeTyson wrote: ↑Thu Dec 14, 2023 11:45 amNot totally related to this thread, but to your comment. I have a Ready to Paint Tarmac and wondering how "ready to paint" it actually is. Just sand the top coat and then primer? I can see the carbon layup so I think it's just a thin matte clearcoat. So maybe like 600 grit wet sanding and good to go for primer, then color? I also have a Tarmac SL7 pro frameset that is similar but has painted logos. Again, I can see the carbon layup so I'm thinking about sanding the logos off and then primer. Good idea?s3si1u wrote: ↑Sun Dec 03, 2023 7:55 pmI've painted several open molds. The standard matte black finish is essentially a "ready to paint" situation. Scuffing it very well with 400 grit or so will suffice for a new spray job, I found adding some good primer before spraying color really helps with adhesion.bikergrove wrote: ↑Sat Dec 02, 2023 9:54 amHas anyone experimented with removing the black matte finish from one of these open mold Chinese frames and subsequently tried painting it? I own an original FM66 frame acquired from Carbon-Zone or Carbon-Cycle on eBay (possibly OEM Hongfu) in 2016, which I've ridden extensively but has been stored for years. Curious about the feasibility, I'm contemplating sanding and repainting it. The original finish appears to be a matte black that resembles primer. Could I potentially spray over it with minimal preparation, or is a more involved process necessary? While I anticipate the likely answer is no, I'm interested in hearing from fellow WW members who may have firsthand experience.
I spent about 30 minutes sanding last night with 400 grit wet/dry which truth be told, hardly did anything.
I've also gone the full way and removed the matte black completely before primerimg and painting and I find you don't really need to go through all that trouble unless you really want to save an extra 7-10 grams or so.
As far as your SL7 pro frameset, I also recently repainted my Winspace SLC frameset with a similar finish, but it was matte clear with gloss logos. I sanded it down until the logos were removed and flat with the rest of the frame. I tried to remove all the clear for the sake of weight on this one.
