Bibs with thick chamois pads
Nexus11
by Nexus11
After making some tests trying to find a better saddle for me,the winner is a selle smp forma.
I want to change some bibs because the shop that i'm buying a lot of equipment is not selling with thick chamois pads. The old models have a thickness of 15mm with gel(the bibs they were from Decathlon).For a saddle without any padding those bibs are good but i don't find any new ones.
For online shopping which brands have thick chamois pads?The premium bibs don't show much information about the chamois in the descriptions.Can anyone recommend some brands? Also if it's possible that the inseam of the bibs not to be that long. (some 5" inseam)
If it's not posible to have both options(thick and relative short) i remain on the thick chamois option.
lukaszzsch
by lukaszzsch
Assos mille gts/gto have respectively 11/16 mm of pad thickness. Worth trying
micky
by micky
Over the years I've found thicker pads (as long as not bulky to rub on legs) to work for me better than thin ones.
Both Alè and Giordana bib pads are rather thick.
When I was involved with a brand and we made bibs at Nalini, their pad thickness was the sweet spot for me.
kode54
by kode54
lukaszzsch wrote:Assos mille gts/gto have respectively 11/16 mm of pad thickness. Worth trying
I use the GTOs and like their plushness. It’s memory foam so compresses well.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
wltz
by wltz
Bioracer’s Vapor pad is quite thick. I prefer thinner, so didn’t get on with it, but some forum users said they liked it a lot.
poulhansen
by poulhansen
Asos Mille has thick pads and they are dense. Many, even thick pads, are made of soft foam, that you can squeeze together with to fingers.
But I don't use them for touring in the tropics. If you stop at a sight or market. Walking around with sweaty foam will give you abbrasions on the bum within ½ hour.
Cannondale Super Six HiMod 2017 6.7 kg
Cannondale six13, 2004, 5.50kg
Focus Izalco Max, 2023 4.418 kg
MichaelB
by MichaelB
RedWhite bibs are also well padded and great value
EdWiser
by EdWiser
Black Bibs Ultimate are good thick pad.
80 bucks
https://theblackbibs.com/products/the-b ... s-ultimate
C36
by C36
I had a look at a LBS sales over the weekend and saw that some Mavic pads are REALLY thick.
London9921
by London9921
C36 wrote:
Thu Sep 07, 2023 1:42 pm
I second that. Used Mavic in the past and their essential (I believe they were called) were relatively thick and comfy.
If you've got Verge distribution where you live their general chamois pad is relatively thick and dense. Super comfy imo.
sevencyclist
by sevencyclist
Assos Mille GTS is 13mm thick, Assos Mille GTO is 21mm.
This is according to the resonse I got from Assos sales team.
From my experience, the GTO is the plushest I have ridden.
