Third party replacement Oakley lenses
Kit Brand Talk. Everything under the sun, including sunnies!
pushpush
by pushpush
Does anyone have experience with the cheap replacement lenses? I see tons of them. Do any of them perform acceptably? I'm struggling to rationalize 80 bucks for a dollar of plastic.
kervelo
by kervelo
No experiences, but I am pretty sure the quality of the cheap knock-offs is not the same as the original Prizm lenses.
GaBa
by GaBa
I just bought two replacement lenses for Jawbones, at 50-58€ (prizm low light and prizm black) they seem reasonably priced and I would not think for a moment to buy knock offs.
Cranzai
by Cranzai
Good question, would be interesting to know what experiences people have.
This summer I bought a pair of Oakley Sutro S, wonderful glasses, absolutely love them.
However, I find that the prizm sapphire can be rather dark with the current daylight.
Hence, I would be interested in buying a clear lens (or photochromic) but Oakley does not offer these options for Sutro S...
Spotted these on amazon but no idea about the quality.:
https://www.amazon.nl/Compatibele-verva ... uage=en_GB
pushpush
by pushpush
A lens is a piece of plastic with some coatings sprayed on it, most likely while under vacuum. It doesn't warrant the $80 price tag.
Optically in terms of clarity, I have multiple pairs of glasses that were <$20 that are just fine. I'm mostly wondering about the quality of the coatings.
I guess I'll just try a couple and find out.
Kayrehn
by Kayrehn
Don't have to overthink it, original Oakley lenses have the shittiest quality in terms of coating longevity so save yourself 70% of that cost and get something cheap. I speak from experience as someone who used it for a decade before the quality went to shit.
Sent from my Pixel 6 using Tapatalk
kytyree
by kytyree
I've replaced a few of mine with ones from Revant and I think they work pretty good for the price. They're better than scratched or damaged Oakley lenses or not using a perfectly good frame that just needs lenses.
jfranci3
by jfranci3
pushpush wrote:
Fri Oct 13, 2023 5:52 am
One way to look at it is a shiny bit of plastic, but a good curved lens is hard to make. Im not talking about normal sunglasses (base 4 curve), but wrap around ones take some engineering. If you get a cheaper ones, they're going to be pretty wavey off center. The coatings are another difference - the Oakley ones are going to be a lot more durable lenses and the oil-phobic coating will last a lot longer (basically more difficult to apply coatings). The Oakley ones are either PolyCarb or Trivex lenses, which is a lot tougher than plastic.
Anyway, don't spend too little. The Fuse and Revant lenes are probably the way to go. For the lenses with the AR and Oil-phobic coatings, you're probably at $60, so it might be worth the $80 for the known quality lenses.
pushpush
by pushpush
I will checkout Fuse and Revant. Thank you!
nickf
by nickf
Kayrehn wrote:
Fri Oct 13, 2023 6:36 pm
This. My Oakley lenses never last. I'm done spending $150 on cheap plastic. Been using the Tifosi Vogel SL. At $40 a pop I don't cringe when I drop them.
