The wheelbuilding thread
Forum rules
GreenBlood
by GreenBlood
As mentioned in my welcome post, I am looking to building the same wheels -etc as twisted wheels. Light Bicycle AR25s with Extralite cyber smart 3 hubs and titanium carbon spokes. (It seems the spokes are hard to come by, brisk don't sell them anymore, but interestingly, Ali express has identical looking ones for sale at 7euro a pop)
I need to find out what lenght spokes I need for this combination. I have never built wheels before so need to gen-up well before ordering stuff.
Any help appreciated.
Steve
MrB123
by MrB123
Light Bicycle will probably assist you if you ask them.
calumfindlay
by calumfindlay
Hi all. I have been deliberating over my next rim brake wheel build for a while and finally pulled the trigger on the following components:
DT Swiss 240 Classic Rear Hub 28h
DT Swiss 240 Classic front Hub 24h
DT Swiss RR 411 asymmetric rear rim
DT Swiss RR 411 front rim
DT Swiss competition 2/1.8/2 spokes
Sapim alu nipples
I would have normally opted for Sapim Race but there wasn't availability in my size. I'm starting to think i should hold out for better spokes, but I keep telling my self to not be ridiculous.
Do I need to stop overthinking this??
TidyDinosaur
by TidyDinosaur
calumfindlay wrote:
Sun Aug 27, 2023 8:33 pm
Sapim alu nipples
What would you see as "Better spokes"?
You could go for the Sapim Laser if you want to save some more weight. I build all my wheels with them...
calumfindlay
by calumfindlay
TidyDinosaur wrote:
Mon Aug 28, 2023 8:07 am
Sapim alu nipples
I have built with Sapim Race in the past, as I thought this was the "better spoke". For some reason I have associated stiffness with these spoke but looking into it a bit further Im not sure if that is the case. I just looked at the laser spoke, they would make the wheels somewhere in the region of 80-100g lighter. Maybe something to consider on the next rims.
birdrider
by birdrider
What are your guys thoughts on 21h 2:1 hubs for disk brakes? I recently built up a pair of AR56 wheels with 24 holes. The front is noteably more affected by cross winds. I think it's down to the spoke count. I'm coming from rim bake wheelsets with the spoke counts from 16-20h. I think the spoke count is often overlooked when it comes to stability.
https://www.aliexpress.us/item/32568036 ... JsKZbXx3Kp
I was looking at these hubs and my only worry is about the rear hub and not having cross lacing on the disc brake side.
Scott2017
by Scott2017
GreenBlood wrote:
Fri Aug 18, 2023 10:21 pm
Steve
Brisk doesn't sell its carbon spokes anymore?
Catagory6
by Catagory6
hi, don't know if this one was covered, but wondering if an Aerolite spoke can be used to replace a CX-Ray spoke?
i'm doing a wheel build and am 1 CX-Ray short, but i have the Aerolite
its in a 2-cross rear DS rim brake, if that matters
kafreeman
by kafreeman
Similar dimensions, I don't see a problem.
Sent from my SM-G998U using Tapatalk
garbageman
by garbageman
My front wheel has 23 cx-rays and 1 aerolite. it will work.
trainingpartner
by trainingpartner
Shimano C24 tubular rim same ERD as the clincher?
petal666
by petal666
trainingpartner wrote:
Wed Oct 25, 2023 12:49 pm
Compare the spoke lengths in the exploded diagrams. si.shimano.com
tfayet
by tfayet
petal666 wrote:
Thu Oct 26, 2023 12:53 am
Same spoke lenght for front
Not same length for rear but not the same construction: 2*10 spokes cross*2 on C24 clincher; and 14+7 spokes on C24 tubular with cross*2 freehub and radial for the non freehub.... So difficult to know if same ERD for rear rim
trainingpartner
by trainingpartner
tfayet wrote:
Thu Oct 26, 2023 7:10 am
Thank you 🙏
Greny
by Greny
Got a question about respoking my wheels , a pair of Reynolds AR 41 DB. https://road.cc/content/review/261898-r ... b-wheelset
They came standard in my Scultura 8000. Got the bike 10 days. Finally got around weighing all components this morning
and saw that the spokes are straight non butted non aero model with brass nipples.... they weigh 1620 gr rimtape installed.
I was figuring that if I rebuild the wheels (48 spokes) to Cx Ray and alloy nipples I gain approx 150 grams and ofc the aero effect.
When I look spec manual Reynolds site it says SPOKE, SPM SPRINT SP 283MM BLK. But sprint straight pull non aero, non butted doesn't excist .
Of course could be made specific for them by Sapim. What your thoughts guys ?
