Zipp 202 rear hub
Forum rules
spud
by spud
This a question from out in right field - does anyone know if the Zipp 182 freehub is compatible with the 202 hubset? I've got an old clincher wheel built on a 202 hub that had the freehub fail. Rather than trashing the wheel, which is otherwise good, I'd like to replace the freehub, and the 202 design is no longer available. The 182 and 202 freehub use the same bearings, but the 202 mounts on the driveside, retained with a screw on cap. I believe the 182 mounts from the NDS and is captured by the DS shoulder on the axle.
