How can a wheel like this pass QC?
Forum rules
GravelFactor
by GravelFactor
I have a rear wheel where it was impossible to get a tubeless tire (GP5000) to seal (hooked rim). After inspection, I found that part of the bead was not shaped correctly, see picture.
I have started a warranty case with the seller.
I am shocked that this rim can pass QC and go into wheel production. Have anybody experienced something like this?
[/img]
Lelandjt
by Lelandjt
No, and I work at a shop so I see a lot of rims. What is it?
MagicShite
by MagicShite
is this an Enve?
fatpinarellorider
by fatpinarellorider
I'm surprised you didn't notice that when you were mounting the tyre.
Jaisen
by Jaisen
Why are you hiding the brand? If it is a big brand name, surely it would be a service to others on the forum to know that brand has poor QC. If it is some ultra cheap aliexpress wheel, then I guess it is to be expected.
jdecraene85
by jdecraene85
It looks like a very poorly executed construction to make up for the weight of the valve on the other side of the wheel? But it's indeed to close to where the bead is supposed to sit.
EtoDemerzel
by EtoDemerzel
That looks like it was damaged and sloppy repair
jlok
by jlok
MagicShite wrote:
Fri May 10, 2024 1:02 pm
is this an Enve?
I thought of the same at first, but judging from the access holes I think it is not Enve.
cleanneon98
by cleanneon98
Don't have to worry about passing QC if you don't do it, is my guess
TREK Madone Gen 7 SLR - 7.43kg
TREK Fuel EX Gen 5 - overbuilt and overweight
mikehhhhhhh
by mikehhhhhhh
The state of the finish on that, I'm not surprised.
Cheap chinese wheel?
Lelandjt
by Lelandjt
EtoDemerzel wrote:
Fri May 10, 2024 3:29 pm
That's a patch where there's a hole in the initial layup to remove the bladder. The patch was installed sloppily.
GravelFactor
by GravelFactor
Hello everyone,
I just blinded the wheel to avoid a brand bashing. But since it has been guessed, I'll say that the wheel is a new Enve SES 5.6.
I didnt notice the fault because a mechanic mounted the rim tape before I mounted the tire.
To make things worse, the front wheel had two faults: 1) 15 mm end caps were mounted which took a long to get replaced, 2) a large piece of green bladder was left inside the rim. Luckily it flipped so I could pull it out. Otherwise that alone had been a warranty case. Unrelated faults but only possible due to completely inadequate QC. But not compensated for by Enve customer "service".
toxin
by toxin
mikehhhhhhh wrote:
Fri May 10, 2024 5:10 pm
Lol
Jaisen
by Jaisen
GravelFactor wrote:
Fri May 10, 2024 7:50 pm
Hello everyone,
Thanks for sharing this additional information. This is rather disappointing from Enve, I honestly would have expected much better from the brand.
EtoDemerzel
by EtoDemerzel
So Enve would not simply replace this wheel? Are you having to fight them on this?
