Tire width list
Forum rules
froze
by froze
Fleckinger wrote:
Mon Mar 18, 2024 1:22 pm
froze wrote:
Mon Mar 18, 2024 1:27 am
Schwalbe Marathon Almotion 38 measured 41
Panaracer Race A EVO3 25 measured 25 (leave it to the Japanese to be exact!)
Bontrager AW3 25 measured 27
Bontrager H5 Hard-Case Ultimate 45 measured 47
Vittoria Open Pave CG iii 25 measured 27
Which rim/wheels do you use?
Got the internal measurements listed next to the tires now, thanks, hope that helps
Fleckinger
by Fleckinger
froze wrote:
Mon Mar 18, 2024 4:45 pm
Yes, thanks.
MarcFaFo
by MarcFaFo
Fleckinger wrote:
Thu Mar 14, 2024 10:17 am
MarcFaFo wrote:
Wed Mar 13, 2024 10:22 am
Can't get the file edited
Tufo Comture Prima TR 25mm measure 28.3mm on 21 internal / 28.6 external hooked tubeless rim Craft 50/55 - 5,8bar
Thanks for your reply, I added your measurements to the list.
Yes, I made the file read-only because I want to keep the list consistent and avoid a situation where someone decides to delete the data.
Than I am 100% onboard. To keep it clean, the best way to protect your hard work is to own the list :thumbup:
fulton
by fulton
22C rim Hooked, 28mm GP5000 , 75PSI WMA: 29.4mm
Geraint
by Geraint
Conti GP5000STR 32c, LB WG44 (30mm internal width), WAM = 35.8mm
Conti GP5000STR 32c, LB WR50 (25mm internal), WAM = 34mm
Rene Herse Barlow Pass Extralight 38c, LB WG44, WAM = 43.4mm
Vittoria Corsa Control 30c, LB WR65 (25mm int), WAM = 32.8mm
Vittoria Corsa Speed 25c, Roval Rapide CLX II, WAM = 27mm
svennn
by svennn
Fleckinger wrote:
Tue Mar 12, 2024 8:58 am
Hi, if you were wondering how wide tires will inflate on a rim with a certain width, but didn't want to spend a lot of time searching all over the internet, I have collected a list of tires and rim combination with real WAM in one excel table - https://1drv.ms/x/s!AhEutlGtetB0m6pfdse ... g?e=o7KMZm
If you'd like to contribute - just write here in format "Wheel brand and model, internal and external width, hooked/hookless, tire brand and model, pressure (optional), measured tire width", and I'll add your measurement to the table.
I finally got my tires mounted up on new wheels to measure things. It turned out exactly as I wanted for a fast all road/gravel bike.
Nextie AGX NXT45, 29mm ID, 40mm OD, Hooked, 35mm GP5000 AS , 40PSI WMA: 40mm
tiberiade
by tiberiade
Somehow I can't open the document — any idea why?
Fleckinger
by Fleckinger
tiberiade wrote:
Mon Apr 08, 2024 7:34 pm
I tried from two PC, three browser, one android phone, two different VPN and without VPN, incoginto and normal tab, the document opens correctly.
BernieMoves
by BernieMoves
Vittoria Rubino Pro G 2.0 28c, Fulcrum Racing 6 DB (20mm internal width) - measured 30mm
froze
by froze
Fleckinger wrote:
Tue Apr 09, 2024 11:58 am
When you first posted it I couldn't open it either, but I tried it again today and it worked just fine.
AZR3
by AZR3
I had the file opened last week and could filter the columns but I cant seem to do that anymore?
Fleckinger
by Fleckinger
AZR3 wrote:
Thu Apr 11, 2024 1:02 am
I think I fixed it, try it now.
AZR3
by AZR3
Fleckinger wrote:
Thu Apr 11, 2024 7:33 am
Its working like before now, thanks!
AZR3
by AZR3
Just going to add my LB AR56 23Int/30Ext with Specialzied Turbo Cotton 28 "Hell of the North" - 29.6mm@67psi
rudye9mr
by rudye9mr
Wheel Brand: Ursus
Wheel model : Miura T37 Disc
Rim Type: hooked
Rim Internal width (mm): 21
Rim External width (mm): 29mm*
Tire Brand: Michelin
Tire Model: Power Road
Tire Width: 28 mm
Pressure (PSI): ca. 55/58 psi
Measured Width (mm): 30mm
*29mm at widest, measured with vernier
