Tire width list
Forum rules
Fleckinger
by Fleckinger
Hi, if you were wondering how wide tires will inflate on a rim with a certain width, but didn't want to spend a lot of time searching all over the internet, I have collected a list of tires and rim combination with real WAM in one excel table - https://1drv.ms/x/s!AhEutlGtetB0m6pfdse ... g?e=o7KMZm
If you'd like to contribute - just write here in format "Wheel brand and model, internal and external width, hooked/hookless, tire brand and model, pressure (optional), measured tire width", and I'll add your measurement to the table.
jayjay
by jayjay
Good work!
Very nice first post after beeing a member for 7 years :D
jayjay
by jayjay
Rim Brand: Nextie
Rim Model: NXT40GX
Rim Type: hooked
Rim Internal width (mm): 22
Rim External width (mm): 29
Tire Brand: Continental
Tire Model: Grand Prix 5000
Tire Width: 28
Pressure (PSI): ca. 75
Measured Width (mm): 29.5
OtterSpace
by OtterSpace
Light Bicycle has a huge list of what tires they have tested on their rims, the WAM, how difficult the install was, and installation notes to help their customers select the right rim and drive sales. Their list is grouped by rim width so if you have rims from another vendor its easy enough to try and find an equivalent.
Fleckinger
by Fleckinger
OtterSpace wrote:
Tue Mar 12, 2024 5:24 pm
Yea, they did a good list, but it lacks 30+mm tires, and some new model, like gp5k S TR, or AS TR, which fits a little different than old tubed or TL versions.
UrgentDelay
by UrgentDelay
You can incorporate my list, multiple measurements for certain tire/rim combos: viewtopic.php?f=132&t=174930
Fleckinger
by Fleckinger
UrgentDelay wrote:
Tue Mar 12, 2024 5:58 pm
Thanks, I did.
UrgentDelay
by UrgentDelay
Fleckinger wrote:
Tue Mar 12, 2024 8:09 pm
Thanks, I did.
Super useful list, thanks!
MarcFaFo
by MarcFaFo
Can't get the file edited
Tufo Comture Prima TR 25mm measure 28.3mm on 21 internal / 28.6 external hooked tubeless rim Craft 50/55 - 5,8bar
Fleckinger
by Fleckinger
MarcFaFo wrote:
Wed Mar 13, 2024 10:22 am
Thanks for your reply, I added your measurements to the list.
Yes, I made the file read-only because I want to keep the list consistent and avoid a situation where someone decides to delete the data.
jayjay
by jayjay
Fleckinger wrote:
Thu Mar 14, 2024 10:17 am
As someone who works a lot with Excel lists, I totally understand that :D
froze
by froze
Schwalbe Marathon Almotion 38 measured 41 using a 23mm internal width rim.
Panaracer Race A EVO3 25 measured 25 (leave it to the Japanese to be exact!) 14mm internal width rim.
Bontrager AW3 25 measured 27 on a 14mm internal width rim.
Bontrager H5 Hard-Case Ultimate 45 measured 47 on a 20mm internal width rim.
Vittoria Open Pave CG iii 25 measured 27 using a 15mm internal width rim.
DogmaHiFi
by DogmaHiFi
Wheel Brand: Princeston
Wheel model : wake 6560 evolution
Rim Type: hooked
Rim Internal width (mm): 21
Rim External width (mm): 28.2
Tire Brand: Pirelli
Tire Model: Pzero TLR SL
Tire Width: 28 mm
Pressure (PSI): ca. 85
Measured Width (mm): 29.3
garbageman
by garbageman
Farsports Gravel FS30/30GH-700c, 24mm int/30mm ext, hooked, Vittoria Corsa Pro 700x30c, 60 psi, 32mm
Fleckinger
by Fleckinger
froze wrote:
Mon Mar 18, 2024 1:27 am
Which rim/wheels do you use?
