Anyone got experience of the veloflex Corsa evo 32mm VS Vittoria corsa control 30mm?
How do they compare in size on the same rim?
Currently got the corsa control on my rear wheel on a 19mm rim, want to try the veloflex in 32mm but don't want to go any wider.
My experience with veloflex in other sizes is they usually run on the smaller side, so numbers on the tyres aside, I'm guessing they might be slightly narrower than the vittorias.
Veloflex vs Vittoria width question
Forum rules
I m using standar Vitoria Corsa pro and veloflez Corsa Evo tlr on my 22mm internal width rims.
-Front Vittoria corsa pro 30 is 31mm wide with 5 bar pressure.
-Rear veloflex Corsa Evo tlr 32 is 33mm wide also with 5 bar pressure.
Veloflex looks way bigger because thread is much wider than Vittoria.
Thanks xabi. That is exactly the info I needed. Much appreciated.Xabi wrote: ↑Sun Feb 11, 2024 7:17 pmI m using standar Vitoria Corsa pro and veloflez Corsa Evo tlr on my 22mm internal width rims.
