Michelin Power Cup Clinchers
Forum rules
Will you ride off the edge and destroy your £10k bike?
Yes, they’re death traps
13%
Yes, if you run 25s and corner like Pidcock
16%
Yes, if you run 28s and corner like Pidcock
3%
No, for 99% of riders they’re fine
26
68%
Total votes: 38
Ferry
by Ferry
I was also on the fence about the Michelins but decided to try them anyway. I have been on Vittoria Corsa, Veloflex and Turbo Cotton S (Hell of the North) the last two years. I have just mounted the tires on CLX 50 (21 mm internal) with Vittoria latex innertubes. The measure 29 mm (1 mm more than the Turbo Cotton S Hell of the North). I am riding these tomorrow and will let you know what I think of them.
Ferry
by Ferry
Only 100 kilometres done, but it's really simple: these roll fast. Yet less supple than the cotton clinchers I am used to.
No problems with grip either.
Mr.Gib
by Mr.Gib
I don't trust these tires. Not in wet, not in dry. Very fast, very smooth and quiet rolling, but they feel quite squirrely on uneven surfaces. Like they deflect of road imperfections, worse in the wet. I'll post more detail in a few weeks - no time at present.
Here they are in action a few days ago. I thought I knew extreme conditions but this was nuts. (I should post in On the Road forum. The guy who took the photo is a genius and one hell of a rider)
Image.
wheelbuilder
by wheelbuilder
Great iconic photo. Chapeau!
alanyu
by alanyu
Mr.Gib wrote:
Mon Jun 24, 2024 9:04 pm
Image.
FurkaPass?
Greeners
by Greeners
I'm heading off to the Pyrenees with my new Power Cups in a few days. I'll be sure to add my findings.
So far only used the tyres locally prepping the bike, they feel very supple from what I can tell.
Sub2
by Sub2
I've got a couple of hundred miles on my 28s, they roll well , comfortable and look the biz in tan and black 👌
Will def replace with same when the time comes.
Mr.Gib
by Mr.Gib
Mini update.
As the tires have worn I have become more at peace with them. I wonder if the issue was the factory finish. The thing that really raised my suspicions was riding over textured metal service covers in various towns, particularely in the wet. Now I know I am taliking about wet metal, but the tires would always slip down to the lowest point on the covers. So if a manhole cover had raised bumps, the tires would slip one way or the other if they tracked over a bump. At times I could feel the tires kick a couple of centimeters sideways. Fact is I have ridden over hundreds of such covers over the years on other tires and never had this experience. Also beware of wet wood bridges. The knots wear slower then the rest of the wood leaving little side slopes that can cause similar side-slipping. I recommend scuffing the full tread of the tires with sand paper before use. Perhaps that will help.
More later.
MAJ
by MAJ
ads wrote:Will i mash up my bike?
At the moment for me better than Continental GP5000 S TR
Enviado desde mi CPH2449 mediante Tapatalk
ads
by ads
I went with the 28mm TCs in the end and really like them. Can't see myself needing to switch whilst I'm still running tubes. Great tyres.
Mr.Gib
by Mr.Gib
And last words.
During one rainy ride I decided to conduct a non-scientific wet metal grip test. Standing beside the bike hands on the drops, with the front tire on a wet metal service cover, I tilted the bike at modest angle and pushed down on the front end while gradually increasing the angle. The Michelin Power Cup clinchers would offer momentary resistance and then completely release. Then I repeated the same test in the same spot with Mrs. Gib's bike with Vittoria Corsa Control 2.0. Clear difference - the Corsa had greater initial resistance and released more gradually. Repeated the test multiple times swapping back and forth between the two bikes. The difference was quite obvious, well beyond an "it's all in my head" thing. Of course such a test could have zero relevance to actual riding on tarmac.
Something else that I wonder about is if the Power Cups' profile is "pointier" and steeper sided then the Vittoria Corsa's that have worked for me in the past. The 28mm power cup occasionally rubs the underside of the rear brake bridge. 30mm Corsa Controls never did. I wonder if this different shape contributes the traction problems I have been noticing.
And a final data point. From the very first ride in the wet on the Power Cups, I noticed more rear wheel slippage that I can ever recall with other tires. In particular, if my rear tire rolled over a small stone, I would of course experience the initial slip that you would feel with any tire as the stone gets spat out, but with the Power Cups, the slipping would continue for a bit after the tire re-connected with the tarmac. Even Mrs. Gib noticed and commented.
That's about all I have on these tires. I fully expect that others will find these tires to be perfectly good. Perhaps in some applications under different riders they are excellent. Michelin knows rubber, and I'd be inclined to doubt my experience more than Michelin's expertise. It will be interesting to see what changes Michelin makes to the tire in future revisions. That may be quite telling about the true nature of the current tire. For example, if we see certain tread changes and marketing promises of "more cornering traction".
CampagYOLO
by CampagYOLO
Mr.Gib wrote:
Tue Jul 02, 2024 8:36 am
And last words.
During one rainy ride I decided to conduct a non-scientific wet metal grip test. Standing beside the bike hands on the drops, with the front tire on a wet metal service cover, I tilted the bike at modest angle and pushed down on the front end while gradually increasing the angle. The Michelin Power Cup clinchers would offer momentary resistance and then completely release. Then I repeated the same test in the same spot with Mrs. Gib's bike with Vittoria Corsa Control 2.0. Clear difference - the Corsa had greater initial resistance and released more gradually. Repeated the test swapping back and forth between the two bikes. The difference was quite obvious, well beyond an "it's all in my head" thing. Of course such a test could have zero relevance to actual riding on tarmac.
Something else that I wonder about if the Power Cups profile is "pointier" and steeper sided then the Vittoria Corsa's that have worked for me in the past. The 28mm power cup occasionally rubs the underside of the rear brake bridge. 30mm Corsa Controls never did. I wonder if this different shape contributes the traction problems I have been noticing.
And a final data point. From the very first ride in the wet on the Power Cups, I noticed more rear wheel slippage that I can ever recall with other tires. In particular, if my rear tire rolled over a small stone, I would of course experience the initial slip that you would feel with any tire, but with the Power Cups, the slipping would continue for a bit after the tire re-connected with the tarmac. Even Mrs. Gib noticed and commented.
Not sure how applicable it is but I've commuted on Michelin Power Gravel's in the past and they were sketchy as hell on cold wet tarmac despite being wide. Never experienced another tyre quite like it. So it could be something to do with the compounds they use.
I know they never test that well but Vittoria tyres do just feel better on the road when it comes to grip.
rudye9mr
by rudye9mr
@ Mr. Gib, what is the ambient temperature for your riding on these?
Mr.Gib
by Mr.Gib
rudye9mr wrote:
Tue Jul 02, 2024 1:01 pm
From 25 down to 5 Celcius
rudye9mr
by rudye9mr
wondering if the compound needs heat to come alive...
