FarSports Kaze 35mm With Extralite Hubs
Forum rules
- Pistol2208
Hi Just ordered these from Wheelsfar:
Extralite Hubs Cyber SP
35mm Kaze Tubular Rim Brake
Sapim Super CX-Ray Spokes
Has anyone had this combination, or close to and what experiences have you had? I've heard the 1:1 gear ration could be an issue, has anyone found this?
Weight is coming in at 954g so looking good to take Factor o2 Down to 4.8KG.
Factor 02 10.9lb / 4.9 KG
Planet X RT80 13.1lb / 5.94 KG
Litespeed Ghisallo 10.2lb / 4.63 KG (sold)
- Pistol2208
Its stated on their website :
'CyberRear freewheel mechanisms are suitable for road and cyclocross use (and not MTB) with a maximum shortest ratio of 1:1.
Shorter ratios may produce excessive torque and damage freewheel mechanism.'
https://www.extralite.com/Products/CyberRear%20SP-2.htm
Im not 100% certain why? guess thats why I'm asking the question.
- Pistol2208
OK, So I guess this means a larger rear sprocket say a 32 (with a 30 front) puts more load on the rear cassette, which is potentially too much for just 2 contact points with the freehub ratchet.
Am I understanding this correctly?
- ultimobici
- in the industry
- Contact:
Not been an issue on Mavic or Hope hubs. Maybe Extralite have skimped on their springs?
that's essentially what they are saying. greater than 1:1 is a lot of torque going through very light components. the strength of the very light axle is probably a factor too. i personally think the two pawl system is an unnecessary weight saving with hit being so minimal. blasphemy in this forum, i know!Pistol2208 wrote: ↑Tue Dec 19, 2023 3:59 pmOK, So I guess this means a larger rear sprocket say a 32 (with a 30 front) puts more load on the rear cassette, which is potentially too much for just 2 contact points with the freehub ratchet.
What pro rider was it a long time ago, maybe in the Tour, who crashed hard when his freewheel slipped under high torque. The mechanic had reduced the pawls from 6 to 3 to save weight and this allowed the freewheel body to distort under load. Anyone remember this?
cycling / nature / music
I think that was Tyler Hamilton, and I recall hearing it was done to save drag when coasting rather than weight. Clearly not a smart move as I believe he injured his shoulder.Miller wrote: ↑Tue Dec 19, 2023 6:01 pmWhat pro rider was it a long time ago, maybe in the Tour, who crashed hard when his freewheel slipped under high torque. The mechanic had reduced the pawls from 6 to 3 to save weight and this allowed the freewheel body to distort under load. Anyone remember this?
- ultimobici
- in the industry
- Contact:
There’s a big difference between altering an existing product and not designing it properly in the first place.Miller wrote:What pro rider was it a long time ago, maybe in the Tour, who crashed hard when his freewheel slipped under high torque. The mechanic had reduced the pawls from 6 to 3 to save weight and this allowed the freewheel body to distort under load. Anyone remember this?
@geezer thanks
- Pistol2208
Sure he had other ways to get bigger performance gainsfastforageezer wrote: ↑Tue Dec 19, 2023 6:44 pmI think that was Tyler Hamilton, and I recall hearing it was done to save drag when coasting rather than weight. Clearly not a smart move as I believe he injured his shoulder.Miller wrote: ↑Tue Dec 19, 2023 6:01 pmWhat pro rider was it a long time ago, maybe in the Tour, who crashed hard when his freewheel slipped under high torque. The mechanic had reduced the pawls from 6 to 3 to save weight and this allowed the freewheel body to distort under load. Anyone remember this?
