Carbon spokes - why?
Forum rules
pdlpsher1
by pdlpsher1
This is interesting. According to China Cycling, DT Swiss has come out with a hub that takes carbon spokes. Does anyone have more info. on this?
https://youtu.be/8ccIc-GK73c?si=wvQ1UGABHYtcEOQ3&t=652
Jaisen
by Jaisen
pdlpsher1 wrote:
Sun May 05, 2024 11:16 pm
Not only that he said DT Swiss has come out with their own carbon spoke range, so it appears it isn't only the hubs. Happens at the 11 minute mark in the video.
Hexsense
by Hexsense
Hensem wrote:
Sun May 05, 2024 9:19 pm
Hexsense wrote:
Sun Apr 28, 2024 10:47 pm
So Light-Bicycle stop trying that idea and only keep making oversized version which require special hub since.
So is this why LightBycycle stopped assembling custom wheels on carbon spokes and only sells “their” carbon wheel sets?
As far as I know. Yes they stopped assembling wheels with carbon spokes which fit every hub.
But they keep the oversized carbon spokes which require a special hub.
But I'm not Light-Bicycle, you can ask them. Maybe they could still build one if you somehow want the discontinued spec.
pdlpsher1
by pdlpsher1
Jaisen wrote:
Sun May 05, 2024 11:27 pm
I interpreted that as hubs that can take carbon spokes, not carbon spokes itself. I guess we'll find out sooner than later.
pdlpsher1
by pdlpsher1
Does anyone know the weight savings between the LB oversized carbon spokes vs. Sapim CX-Ray?
kroem
by kroem
Farsports seem to have those hubs available
Current
Waltly Gravel (stolen... and found!)
P-X Spitfire Ti
Fairlight Strael
Old
Canyon Ultimate SLX 6.7kg (crashed)
Tantan GR039 7.2kg (sold)
Noeh
by Noeh
369g for the pair, seems kinda porky, equivalent to DT350
https://www.wheelsfar.com/ultralight-ri ... p0180.html
2022 Tarmac SL7 Pro for Waifu [7.3kg]
2021 Tarmac SL7 Pro [7.2kg]
2018 CAAD12 [7.5kg]
kroem
by kroem
Oink oink :'(
Current
P-X Spitfire Ti
Fairlight Strael
Old
pdlpsher1
by pdlpsher1
That's too bad. The extra weight negates the lighter carbon spokes.
Ritxis
by Ritxis
Is there any comparison between carbon spokes and Spinergy's PBO? stiffness/weight for example
UpFromOne
by UpFromOne
pdlpsher1 wrote:
Mon May 06, 2024 4:13 am
I have been using the carbon spokes branded as EIE / Nextie / Brisk.
They are from one factory.
The "oval" model is 2.3 x 2.0mm, and in regular lengths (around 290-300) average 2.3g each.
The thin model is 2.3 x 1.6mm, and those average 1.9g each.
CX-Rays are well into the 4 gram range. But these carbon spokes have more tensile strength,
due to the unidirectional layup. So the advantages are many IMO.
THB I have not tried the LB ones. Before I bought any carbon spokes I ruled out the heavier ones,
including the bladed versions at 3.2mm wide x 2.0 thick (or thereabouts).
Carbon comes in all shapes & sizes these days.
But the LB ones would have to be around 2.5g I would guess.
toxin
by toxin
Nextie have an interesting new spoke design, too bad they only make spokes with interfaces for regular straight pull hubs
https://www.nextie.com/carbon-bicycle-s ... ro-NXTCS06
Tensile strength nearly identical to cx ray
cajer
by cajer
toxin wrote:
Thu Jun 27, 2024 4:18 am
That's a really intresting spoke. It even has shaping beyond a elispse.
RDY
by RDY
I saw this. Spoke looks very interesting. But I still don't think normal low flange road hubs are a terribly good idea with carbon spokes.
toxin
by toxin
Seems like just a worse version of the vonoa spoke tbh. It's not even a taperlock design so more prone to failure. The trailing edge doesn't seem like it would carry any load and it probably doesn't cause the spoke isn't very streong.
