New wheels for Aethos
Forum rules
At the moment I'm using Duke Baccara SLS2 36C Ultra rims on dt swiss 240 hubs and planing to keep these wheels.
But for next season I wan't something new/different, so looking at options 40-50mm deep.
Main requarements:
* Stability in crosswinds. (Main requarement)
* Hooked rim (will be used with tubes)
* Deph 40-50mm.
* Ext width 31mm+
* Int width 21-25mm.
* Not looking at chineese rims.
* Weight up to 1400gr.
At this moment considaration list:
1) Reynolds BlackLabel 46 (2023 model)
2) Reserve 40|44 on dt swiss 240 hubs
3) Vision Metron 45
Main requarements:
* Deph 40-50mm.
* Ext width 31mm+
3) Vision Metron 45
PCW Peak with Tactic hubs should be well below 1400
True! I didn't realise they were that much narrower than the Duals and Wake I have.
I know you said no chinese rims, but I just ordered a set of Farsports Hypers 24mm internal/30mm external, 50mm deep with a stated weight of 1207g and around $1K USD - that's pretty hard to ignore.
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
I’m currently using a Light Bicycle AR25 wheel laced to Carbon-Ti hubs on my Aethos. I also have an Enve 2.3 (hookless) wheelset but prefer the LB AR25 wheels o the Aethos. No issues with quality, crosswinds although not deep. Hybrid hook.kode54 wrote:Stability in crosswinds and 50mm depth is an oxymoron.
Not sure they go together.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
From my expirience, a lot depends from rim profile.
My worst ever wheels regarding stability in cross winds was Roval CLX40 (rim brake) and the best - zipp 303fc (2022). Both 40mm deph...
Reynolds and Bontrager RSL have reputation of being one of most stable wheels in this depth.
Yes, Ascent Polaris 42 looks like a good option, but they have limited shipping, doesn't ship to all EU countries.
