Best winter tires for ENVE hookless wheels?
Forum rules
Hey y'all,
I'm looking for a winter tire to pair with my ENVE 3.4 (hookless variant). My bike (an SL8) can take up to 32mm tires and I think I'd like to use all of that clearance!
ENVE compatibility chart looks pretty limited in terms of winter tires. For those of you rocking ENVE wheels, what are you using for winter?
The GP 5000 AS isn't on their list, but Conti claims they're hookless compatible. Looks like a pretty option for the winter. Anybody know if these are good to go?
tepextate wrote: ↑Mon Oct 16, 2023 10:19 pmHey y'all,
Presumably Conti uses the same bead dimensions for the AS TR as the S TR. I would feel pretty confident in putting 30mm and 32mm AS TRs on SES 3.4s...I'd probably even be fine with 28s.
- alexneumuller
- Contact:
I use the Corsa N.EXT TLR G2.0 . They work really well with Enve Rims.
Schwalbe Winter is probably the only real choice for winter riding. Most manufacturers don't do spiked tires at all and this is the only one from Schwalbe line that is made this narrow. I don't think it would work with a hookless rim though.
I ran the 30s no issue
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
