Bitex End Caps
Forum rules
The Farsports rear wheel Bitex TA end cap I have is noticably loose to pop on and off. If you are working on the wheel and you knock the rim even lightly the cassette and freehub are prone to just fall off. Is that normal?
This may well be a case of 'no you're doing it wrong' ... but Farsports also provided an axle with a screw-on end cap but I tried it and the lockring of the disc rotor bottoms out on it when tightened.
Help!
Help!
Canyon Ultimate CF SL
Canyon Grizl CF SLX
Open U.P.
Canyon Grizl CF SLX
Open U.P.
Interesting. My Bitex hubs (from LightBicycle) screw on. For what it's worth I've been pretty happy with the hubs (and my other wheels have DT Swiss 240's).
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
The hubs definitely feel super smooth!
Would you be able to take a photo of the NDS of the wheel so I can see how it's configured?
Canyon Grizl CF SLX
Open U.P.
Canyon Grizl CF SLX
Open U.P.
I also have the screw on model on two wheel sets, and don't have problems with them. I use a mix of light grease and blue Loctite to just gently screw the end cap on so it sits on the NDS bearing without any compression. On my CL hub I have a DTSwiss adapter for 6 bolts rotors (lighter !), and no problems with fit.
Louis
Louis
Thanks for the infoLouisN wrote: ↑Sat Sep 16, 2023 3:27 pmI also have the screw on model on two wheel sets, and don't have problems with them. I use a mix of light grease and blue Loctite to just gently screw the end cap on so it sits on the NDS bearing without any compression. On my CL hub I have a DTSwiss adapter for 6 bolts rotors (lighter !), and no problems with fit.
Louis
Canyon Grizl CF SLX
Open U.P.
Canyon Grizl CF SLX
Open U.P.
