GP5000 AS TR anyone?
Forum rules
bmrk
by bmrk
bobones wrote:
Mon Aug 28, 2023 8:41 am
28s with a few hundred miles on them - zero cuts or loose threads. 370g the pair. They do look as if they'll last well.
Is this weight correct? They are specified 335g for each 28mm tire.
kervelo
by kervelo
bmrk wrote:
Mon Aug 28, 2023 9:47 am
My AS TR 28 mm tyres were 339 and 341 grams, so the 370 g for a pair sounds incorrect.
bobones
by bobones
kervelo wrote:
Mon Aug 28, 2023 9:54 am
Brainfart, sorry, 670 g the pair!
bmrk
by bmrk
bobones wrote:
Mon Aug 28, 2023 11:04 am
Almost went on a buying spree.
RDY
by RDY
Apparently 32 / 35 cream will be available week 3 September.
maxima
by maxima
Have tried my friend;s wheelset with 28mm AS TR in cream color, you can feel the difference coming off Conti 28mm TR........... :unbelievable: petty heavy for a modern tyre. We also seems to have bad luck with sealing with 30-40ml of sealant per real world experiences - end up with 60-70ml of Sealant....juts add to the weight!!!
AJS914
by AJS914
30ml of sealant barely does anything. I don't understand why people even try this. Sealant dries up and eventually weighs next to nothing. The first round of sealant will dry up the fastest. You can top up with 30ml.
Erwin
by Erwin
Looks like a good competitor: Tufo Comtura Prima TR 28
Review at BRR, especially if you want to ride a 28mm AS TR the new Tufo looks good. No wider options available, but the 28mm is 1mm wider than the GP5000 S TR, so a 29mm GP5000 if you want.
RDY
by RDY
Erwin wrote:
Mon Aug 28, 2023 7:23 pm
It looks like THE all season tire, which is what I was expecting, though it's a surprise to see it match the AS TR in their wet grip tests. I suspect RR difference will signficantly narrow to the S TR / Power Cup / Corsa Pro in 30s or 32s when they become available.
TobinHatesYou
by TobinHatesYou
RDY wrote:
Mon Aug 28, 2023 8:49 pm
Wow indeed. Those wattage figures with 50% tread coverage and that amount of grip down the center. Thin sidewalls, but with the widest tread coverage of any tire in its class, it probably won't be a massive problem.
BigBoyND
by BigBoyND
The BRR test looks amazing for this tire. Is 30/32mm confirmed to be coming for the Prima? Great weight for the size, too. Never ridden Tufo before, but this looks like a good one. Are they supple?
Maybe it deserves its own thread 😅
Edit: ignore! I see there is another thread and these things are answered there.
LanceLegstrong
by LanceLegstrong
I'm super interested in these for my winter tire. Thinking about going for the 32s. Do they measure true to size? Would be running them on 21 internal on my SL7. Or could just go big and ride my crux through the winter.
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
BigBoyND
by BigBoyND
For sizing on 21mm IW, you can use BRR and add 2mm
ViperFFM
by ViperFFM
ViperFFM wrote:
Sun Aug 27, 2023 9:03 pm
Could you share pics of the sidewall?
Sexy i like it
carbonLORD wrote:
Fri Mar 12, 2021 12:23 am
I'm a CAT 3 Masters racer, not a dentist.
ducman
by ducman
Gonna get the 35mm AS version of this tire, so i can ride at 4bar, better chance it seals little holes then @ high pressure.
Anybody soms experience on these tires?
