Forum rules
Nickldn
by Nickldn on Thu Aug 03, 2023 7:39 pm
RDY wrote: ↑Thu Aug 03, 2023 7:28 pm
I'm also amazed nobody has brought up that new SRAM (Zipp) patent in this thread ... the one where they delineate their new idea of GLUEING hooks to hookless rims for tire retention. Which to me is a tacit admission that hookless is both a problem, and is being used because it's cheaper (glue on hooks would lead to fewer QC rejects than molded hooks and thus lower costs).
Retrofit to current Zipp rims which are no longer suitable for 25mm wide tyres according to ETRTO?
Maybe Zipp will be sending out kits with glue.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
TLN
by TLN on Thu Aug 03, 2023 7:51 pm
I'm ok with hooks if it raisses allowed pressure back into "hooked nubmers". Basically telling me that I can do 90psi with 28c tire on 25mm glued-hooked. (Not that I need 90 psi, but still)
wheelsONfire
by wheelsONfire on Thu Aug 03, 2023 7:55 pm
TLN wrote: ↑Thu Aug 03, 2023 7:51 pm
That's right
Bikes:
Open *UP* (2016.04.14)
BikeEatSleepRepeat
by BikeEatSleepRepeat on Thu Aug 03, 2023 8:04 pm
Very interesting, and telling, it certainly seems.
JWTS
by JWTS on Thu Aug 03, 2023 9:53 pm
For what it's worth, I think it's silly to run a race tire hookless. There's just not enough headroom if you're running higher pressure with a narrow (25 or 28) tire.
That said, I also think it's silly to run anything more narrow than 30 or 32 unless you're racing, unless you don't have clearance. 32's are so incredibly close to the overall performance, I just don't understand running a narrower tire unless you have a number pinned on. And in my opinon, there is absoutely a potential benefit to hookless with a 32: a thicker sidewall that's more impact resistance.
I'm running a pair of cheap Token RoubX wheels; hookess, with 32mm 5000S TR's. I run them at 55-57 PSI, max. There's plenty of headroom, and I have zero worries that they'll come off. The advantage to this set-up is that I can also run them on light gravel with some chunk at about 28 PSI, and the rims still hold up. I do not think a hookless set-up would have held up as well. Impact resistance is absolutely better with a hookless set-up--so those claiming there are "no" advantanges are either misinformed or simply trying to push their own opinion.
If you want to run a narrow tire at high pressure, use a hooked rim. Problem solved.
JWTS
ArtV
by ArtV on Thu Aug 03, 2023 10:00 pm
That's OK. This entire thread, as entertaining and informative as it is, should probably be in the road tire and wheels forum........
Sent from my SM-X800 using Tapatalk
aeroisnteverything
by aeroisnteverything on Thu Aug 03, 2023 10:57 pm
JWTS wrote: ↑Thu Aug 03, 2023 9:53 pm
People ride for different reasons, at different speeds, on different kinds of roads. It's worth keeping that in mind when saying things like "I think it's silly to run anything [other than what I do]".
TLN
by TLN on Thu Aug 03, 2023 11:25 pm
65 psi + heavy rider + shitty home pump + hot outside + going fast downhill = who knows what kind of pressure I got there when I'm riding.
gurk700
by gurk700 on Thu Aug 03, 2023 11:56 pm
spartacus wrote: ↑Thu Aug 03, 2023 6:10 pm
gurk700 wrote: ↑Thu Aug 03, 2023 5:50 pm
spartacus wrote: ↑Thu Aug 03, 2023 3:34 pm
gurk700 wrote: ↑Wed Aug 02, 2023 11:39 pm
ONE HUNDRED PERCENT want conti / extralite to look into his incident and figure out why it happened, improve the product in the future and go from 1 in a thousand to 1 in tens of thousands of incidents if not eliminate completely.
WE ALL KNOW WHAT HAPPENED
but nobody wants to listen
There are variations in tolerances, that's it.And there are no hooks as a backup. Period. No need to investigate.
Y'all are hopeless.
Come back to me when you’ve dealt with your self esteem, anger and superiority complex issues, decided that internet trolling is not a viable hobby and most importantly, grown up to where your mental age matches your physical one.
You're mad because you don't understand how tolerances work, not my problem.
If you follow your thought process to its logical conclusion then we would end up with impossible to meet standards of tolerances, or hooks.
But you're kinda right, there's no reason to post online anymore because people don't listen to me, and all anyone does is bitch about anything that's new or argue especially when they're wrong. It's all whataboutism or bitching about how "you aren't pro" so you don't need to do X and Y. SO BORING!
yeah man. you really need to see someone for your issues mentioned above. This isn't normal behavior. Do you even work in a professional setting? Do you have do deal with other people? Do you have to consider other people's perspectives in your personal or professional life?
All rhetorical ofcourse. You do you bud.
spartacus
by spartacus on Fri Aug 04, 2023 1:45 am
gurk700 wrote: ↑Thu Aug 03, 2023 11:56 pm
Y'all are hopeless.
No you're right I'm on the street prostituting for crack and I sleep on a pallet underneath the freeway.
I don't know why you're snowflaking so hard rn about your "perspective" when the discussion is basically about the tolerances of a rim and the tolerances of a tire and what happens when both of them are off in the wrong direction.
But sorry I hurt your feelings so bad.
