Continental GP5000 TT TR
Forum rules
Aryeh
by Aryeh
I just installed these on my Farsports Hyper 25mm internal 30mm ext. rims.
I started off with a pair of 28mm tires that weighed 260g each, (my 1st pair of S TR were 265g in 28mm) and they measured 31mm at 80psi.
I decided to switch the front to a 25mm and it measures 28mm at 80psi and weighs 211g. Its crazy to me how much heavier the 28mm is.
Maddie
by Maddie
The 25 int / 30 ext from Farsports is hookless, right? If yes, riding a 25mm or even 28mm tire is out of spec and not considered safe. Be careful
Aryeh
by Aryeh
Maddie wrote:The 25 int / 30 ext from Farsports is hookless, right? If yes, riding a 25mm or even 28mm tire is out of spec and not considered safe. Be careful
They make both hooked and hookless versions. Mine are hooked.
Maddie
by Maddie
Then it's fine, thanks for clarifying.
Was not aware that 25 int is also available with a hook. I thought hooked rims are 24 int/30ext only. Good to know that there is another option for hooked.
Aryeh
by Aryeh
Maddie wrote:Then it's fine, thanks for clarifying.
My mistake. They are 24mm int
JayOJonson
by JayOJonson
How are people finding these over long term use? Specifically looking at the 28's tubeless are they to fragile as a daily tyre?
TobinHatesYou
by TobinHatesYou
JayOJonson wrote:
Wed Mar 13, 2024 9:17 pm
I find them OK as a daily tire, but probably just barely based on quantitative testing by BRR.
spdntrxi
by spdntrxi
TobinHatesYou wrote:
Wed Mar 13, 2024 10:07 pm
how many miles you getting before replace ?
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
bobones
by bobones
Heard on an Escape Collective podcast that the whole Ineos team rode the TT TRs in the TdF last year and didn't get a single puncture the entire race.
Personally riding the 25s on one bike and haven't had any problems. To my mind, they're much more reliable than Corsa Speeds and on a par with Corsa Pros as every day tyres.
TobinHatesYou
by TobinHatesYou
bobones wrote:
Thu Mar 14, 2024 12:04 am
Anecdotally agree with this. I switched to Corsa Pros on another wheelset and got two punctures in maybe 10 days of riding. My only puncture with GP5K TT TRs was at race speed riding across a deep rain gutter that traversed a street. The transition from concrete gutter to asphalt had an edge.
Mileage-wise, I don’t actually know because they’re on my least often used wheels/bikes. 2000mi at least.
spdntrxi
by spdntrxi
I will try them next thanks.
2023 Pivot E-Vault
Mocs123
by Mocs123
Very nice! I just put a pair of 28's on my main (dry weather) bike, and plan on using it on group rides, gran fondo's, and a few races this spring, summer, and fall.
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
BigBoyND
by BigBoyND
Can they please just launch the TT TR and S TR with the cream sidewall of the AS TR?
mikehhhhhhh
by mikehhhhhhh
BigBoyND wrote:
Fri Mar 15, 2024 7:36 am
Amen!
bobones
by bobones
My cream AS TRs got dark very quickly and they're now about the same shade of brown as the tan S TRs. :noidea:
