Craft Racing wheels - carbon spokes 1180g
Forum rules
toxin
by toxin
The wider front is for crosswind stability, nothing else
UrgentDelay
by UrgentDelay
rdhb wrote:
Mon May 20, 2024 2:23 pm
My Supersix with the 6575s 🚀
How would you rate comfort on these? Any difference vs the previous wheelset?
hannawald
by hannawald
toxin wrote:
Thu Jun 13, 2024 10:51 pm
External width is for crosswind stability, but internal? I would expect same internal width front and rear but wider front external width for better aero/crosswind and narrower external width on the rear wheel for lower weight because aero doesn´t matter there.
UrgentDelay
by UrgentDelay
No, it's also there for aero efficiency, but it'd be better if they were even wider, like in Hunt Limitless SUB50 or Roval CLX II
toxin
by toxin
Not how it works at all
spdntrxi
by spdntrxi
you can argue wider front for stability will make you aero overall... but at 0 yaw and probably other yaws as well.. if you are steady you will NOT be more aero on a wider wheel like CLX11 or CRs
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
Hexsense
by Hexsense
Wider wheel increase A in Cd.A.
But it might help wheel+tire mimic teardrop/airfoil shape better, thus reducing the Cd part.
Depending on rim profile but wider wheel can reduce Cd. more than it increase A, given a range of tire size.
I still think 28-30mm tire only require 30-35mm rim though. Wider than that would increase A more than it decrease Cd.
ChinaCycling
by ChinaCycling
spdntrxi wrote:
Sat Jun 15, 2024 4:40 am
I wouldn't deal in such certainties when talking about aero. I agree at 0 yaw a narrower wheel alone will (probably) be more aero than a wider one... but, you have to also think about how the wheel is interacting with the downtube, how the rim is keeping the air away from the spokes, etc, etc. So, I wouldn't like to bet money on which one is faster as a whole.
As always, the only way to be sure is to test it.
spdntrxi
by spdntrxi
ChinaCycling wrote:
Mon Jun 17, 2024 10:59 am
so many variables and outside of a wind tunnel blah blah (which one can argue is not real world) I have not tested a CR but have tested a Roval and it was not faster for "me" and in the end thats all that counts.
2023 Pivot E-Vault
rdhb
by rdhb
UrgentDelay wrote:
Fri Jun 14, 2024 12:12 am
I can't tell any difference in comfort compared to the Hollowgram R-SL 50 wheelset that I was using previously.
spdntrxi
by spdntrxi
rdhb wrote:
Mon Jun 17, 2024 8:12 pm
depending on how you liked you HGs 8) that might be a small victory, as the much deeper and carbon spoked CWs should normally feel stiffer.
2023 Pivot E-Vault
jrbaron
by jrbaron
My 5060s arrived yesterday, and I couldn’t be happier - these beasts enjoy speed!
I also want to shout out to Panda Podium for their excellent support. Initially, I paid for express shipping, but they suggested switching to the regular shipment to avoid extra costs (I’m in Austria). Their customer service was top-notch.
Here’s what I’ve noticed so far:
Acceleration:
These wheels respond instantly to power. Whether I was surging or taking sharp turns that almost stopped me, they went once I pedalled. The feedback to power is simply excellent.
Handling:
The difference is striking in turns. I often felt a bit of flex with my old wheels (MAVICs UST 45), but these new ones are solid and provide excellent feedback.
Speed Maintenance:
Holding speed is another area where these wheels excel. I was able to maintain a consistent pace of around 40 km/h without feeling like I was pushing too hard. They truly shine in maintaining momentum.
Stiffness:
Out-of-the-saddle surges are smooth and free of any brake pad rubbing or signs of flexing. This stiffness translates to more efficient power transfer and a more responsive ride overall.
Initial Impressions:
So far, I’ve enjoyed turning with these wheels, though I still need to test them on a proper climb and downhill to get a complete picture. However, my initial impressions are overwhelmingly positive.
Overall, these wheels have significantly enhanced my riding experience. So far, so good!
mikerthebiker
by mikerthebiker
@ChinaCycling
So, I've had several episodes of the death wobble with this wheelset (I don't think ENVEs were quite as frequent). Any advice on what could cause this? I know this can be weight specific as well, I'm always around 85-90kg. With my equipment, I probably come near the weigh limit. But could this have anything to do with the wheelset hub bearings or anything with the wheelset itself? I might check with my LBS about the headset as well, but I'm just trying to eliminate factors here to have more confidence with downhill speed.
Thank you!
spdntrxi
by spdntrxi
Do you get the wobble with other wheelsets ?
2023 Pivot E-Vault
toxin
by toxin
there could be tens of possible reasons, could be a weight/balance thing, could be an unfortunate combo of tyre and rim aerodynamics, could be a geometry thing. At the end of the day, it's a case specific to you and they only way you'll figure it out is by changing things and comparing results
