Aero plots for wheels
Forum rules
rudye9mr
by rudye9mr
HED Vanquish Aero Road Wheels get Wider & Faster -April 2024
Top level, there are two versions – Vanquish, and Vanquish Pro. All depths are updated, and they’ve replaced hte 40mm with a deeper 45mm option. The entire construction is new, too, from carbon fiber material and supplier selection to layup and rim profiles. And they’re all still hooked, because they believe that’s the safest option....
hey reshaped the rims, with a blunter shape near the spokes. Interior width increased from 21mm to 22.4mm, with a corresponding growth on the outer width, too. The goal of all these changes was to improve aerodynamics with wider 28mm tires. It worked, and not just in CFD. HED took them to the wind tunnel to prove it:
https://bikerumor.com/hed-vanquish-aero ... er-faster/
rudye9mr
by rudye9mr
https://bikerumor.com/hed-cycling-licen ... ecialized/
Specifically, the patent says: “The amount of increase in stall angle due to depth decreases as the tangent angle increases.” In laymen’s terms, Hed’s rep told us the point of the patent is that they can design an optimal range of yaw based on rim and tire combinations, and predict the stall angle.
just an interesting schematic for reference from HED's patent filing (2016)
rudye9mr
by rudye9mr
https://www.dtswiss.com/en/innovations/ ... cted-storm
quite a few aero plots for new Wheel tyre system (WTS) with their ARC and ERC lines at different depths
toxin
by toxin
Tested on their outdated narrow rims so schwalbe aero gets done dirty, no enve raceday either, steering moment compared with gp5k 28mm instead of 25mm
actually enve raceday looks like the same pattern as regular so maybe not a big deal
rudye9mr
by rudye9mr
scapewalker wrote:
Thu Jul 04, 2024 10:54 am
Aero data for 3 of the Vonoa wheels.
Pretty disappointing they didn't test with the 1100 62 DIcut but i might just pull the trigger and get the Vonoa sprint wheels.
from the Vonoa thread - ty @scapewalker
toxin
by toxin
rudye9mr
by rudye9mr
https://specialized.a.bigcontent.io/v1/ ... Tarmac-SL8
not necessarily an aero plot but some reasoning on design based on yaw angles in there that can relate to wheel profile designs based on effective yaw angle
rudye9mr
by rudye9mr
hunt sub50
