2023 - best mid depth carbon road disc wheelset - hooked, min 21mm int, tubeless compatible.
Forum rules
STUB1
by STUB1
Thanks for all the feedback/suggestions. It is important that the wheelset is stiff when doing out of the saddle hill efforts, I feel my current wheels are great on the flats, but definitely feel like they flex when doing out of the saddle efforts (with some rotor rub). I don't know what part of the rim/hub/spoke combo is responsible (The frame is an 02VAM which I suspect isn't the problem because I had the issue on my old bike too). I also don't want to go to a lighter set if they feel like a noodle.
At what width do the benefits of a wider rim start to become a negative for overall smooth road roads? The roads I ride on are pretty good and I currently run a 25 and 28 GP5000 with latex tubes, but would be open to 28 and 28, probably won't go bigger than that/see the need and there for would ID be optimal in the 21-23mm range.
@c36 budget - happy to listen to anything, obviously if a $1500 wheelset performs similarly to a 5k one then I would consider that. I always wanted to try Schmolke, but they were just so narrow until recently (TLO 42).
So carbon spoke options - LW, Partington, Mavic, Newmen - any others?
HBike
by HBike
STUB1 wrote:
Sun May 21, 2023 10:51 am
Cadex (Giant) Ultra 50. Pretty stiff and light
https://www.cyclingnews.com/reviews/cad ... et-review/
Reserve feel plenty stiff according to that review, too
https://www.bikeradar.com/reviews/bikes ... i2-review/
Given the larger outer and inner width paired with no weight limit makes it an interesting option.
Jabulane
by Jabulane
CADEN Cycling
Great products with excellent service. I have three different wheelsets from them and they're all excellent.
https://cadencycling.com/eu/product/45m ... s-wheelset
C36
by C36
From what you discribe, I don't see the absolute need to go 28, a modern 25 on a 21mm rim will already be 26/28mm depending on the brand. This being said you will need to adjust to the final rim choice (the largest won't let you use 25mm labeled tires).
I reuse a table I previosuly published where you can see that light aero and stiff is very difficult to get.
//uploads.tapatalk-cdn.com/202302 ... 50a009.png
Few comments:
- the (missing on that table) Corima MCC DX would be the stiffest option (60N/mm is nearly 50% more than most of the options people quoted above usually around 40-44N/mm) but are 19mm wide internally and 26 externally so a bit narrow for what you were looking for.
- the Cadex would be a good option, but are hookless (but rate them for more than the 5bar limit Zipp has)
- the Mavic Ultimate would be the highest performance overall (light, aero, stiffness) but come at a cost
- I would avoid the Hunt someone mentioned above, they have always been on the flexier side of things
- I was about to suggest Winspace Hyper D45 but for whatever reason have been measured quite flexible by peaktorque (to be taken a pit of salt, his way of measuring stiffness is questionable, usually find lower numbers than anyone else) https://www.youtube.com/watch?v=En2aspS819w&t=488s and the D67 could be too high to be pleasant climbing / downhilling.
- Farsport S series do bring a lot of stiffness (I need to pull data, but on top of my head they are above 50N/mm), their Evo line is still on 19/26
Summary:
- if you have the resources: mavic Ultimate
- if you can live with high pressure hookless: Cadex ultra
- if you are looking for the stiffest/$ value: Farsport S
Jz91
by Jz91
Can anyone confirm this on the Newmen?
NOTE: Due to the spoking, the Vonoa wheels must not be fitted with brake discs smaller than 160 millimeters (small distance between brake caliper and spokes).
grandantipathes
by grandantipathes
Jz91 wrote:
Wed Jun 14, 2023 4:59 am
They were ok with 140mm discs on mine. I think it depends on the configuration
