New Vittoria Corsa Pro!!
Forum rules
nickf
by nickf
I prefer to have a new front tire, if a rear tire gets a puncture it's less of a hazard. Rather have the newest rubber where it's critical.
Tofast
by Tofast
Is anybody running the 28mm tires on rims with inner rim width 25mm? If so how wide are the tires?
also how wide would 30mm tires be on that wide rims?
LedZeppelin007
by LedZeppelin007
Tofast wrote:Is anybody running the 28mm tires on rims with inner rim width 25mm? If so how wide are the tires?
I have. I think they blew up to 30mm. I think 30s were like 32mm.
garbageman
by garbageman
Tofast wrote:
Thu Nov 16, 2023 8:02 pm
I have a 28c and a 30c on 24mm internal rims. 28c is a hair over 30mm. The 30 is 32mm. both at 60psi.
mrlobber
by mrlobber
I doubt you'd find any 28mm tyre less than 30mm on this IW. Most will be 30.5+, the "oversized ones" 31+ mm WAM. Add 2-3mm WAM for 30mm tyres.
Tofast
by Tofast
Thanks for the input guys😊
Trying to decide width for Zipp 303FC and just got answer from Vittoria that 28mm is not officially approved for rim width above 23mm as per ETRTO
CampagYOLO
by CampagYOLO
Tofast wrote:
Fri Nov 17, 2023 9:38 am
I'd run a 28mm tyre on a hooked rim with 25mm internal width but those Zipp's are hookless so I probably would heed Vittoria's advice and not use that combo.
BigBoyND
by BigBoyND
FlatlandClimber wrote:
Sat May 20, 2023 2:37 pm
Yes, officially Corsa Speed Pro will not arrive until 2024, and tire aerodynamics are definitely a little overrated.
While Swiss Side claims un-aerodynamic tries "destroy the aerodynamics of every wheel", all tests I've seen have put the difference from best to worst (with a given width) of 2-4 watts at 45kph. That difference in Rolling Resistance between a very aerodynamic road tire, and a non aerodynamic TT tire is usually bigger than that.
I really hope for the new Corsa Speed Pro to be as fast as the Veloflex Record TLR, with a tread width and wear rate of the GP5000TT. That'd be amazing.
Any word on roughly when in 2024 the Speed is coming?
The 2-4W aero difference seems quite big, depending on speed. The RR difference between GP TT and Speed is less than 1 W, so that would suggest a GP TT on the front wheel would be much faster. And that the Speed is also slower than the more puncture resistant S TR. Makes it seem like the Speed is not a good choice for the front wheel.
RadB
by RadB
CampagYOLO wrote:
Fri Nov 17, 2023 9:54 am
That's the problem with etrto advice, it's mindlessly generic with no actual rim, tyre or manufacturer specificity. It's eye wateringly stupid.
FlatlandClimber
by FlatlandClimber
BigBoyND wrote:
Wed Nov 22, 2023 6:54 am
I don't know anything about the release.
2-4W is probably a pretty high guess. But 2 watts at 45kph would be offset by the difference in rolling resistance:
https://www.aero-coach.co.uk/time-trial ... tance-data
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
floriansantana
by floriansantana
Can anyone who also used the “old” Corsa Graphene 2.0 tell me if there is any point in upgrading to the new Corsa Pro if I’m not planning to use a tubeless setup. I'm looking to buy new tires for this season and can’t really decide if I it’s worth to spend double the money on the Corsa Pro.
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
ultimobici
by ultimobici
floriansantana wrote:Can anyone who also used the “old” Corsa Graphene 2.0 tell me if there is any point in upgrading to the new Corsa Pro if I’m not planning to use a tubeless setup. I'm looking to buy new tires for this season and can’t really decide if I it’s worth to spend double the money on the Corsa Pro.
None.
mikehhhhhhh
by mikehhhhhhh
I'm running this combo. It's on Zipp's own compatibility chart
AXA
by AXA
The new Vittoria Corsa Pro Speed is out!
https://int.vittoria.com/blogs/magazine ... thlon-tire
TobinHatesYou
by TobinHatesYou
AXA wrote:
Fri Feb 02, 2024 12:13 am
It's going to be interesting to see if the Crr gains outweigh the aero losses from not having siping like on the GP5K TT TR.
