(Hookless) What PSI do you run and have you ever blown a tire off?
Forum rules
55-65psi 28mm f and 32mm r on 25mm int wheels.
ETRTO compliant wheels and tyres.
No.
No.
- wheelsONfire
A guy here had a tire come off last week. Yes, he crashed. Don't know what wheels or tires. Heard it from a mech in a bike shop.
Bikes:
Open *UP* (2016.04.14)
28mm tires at 71 rear 63 front
Enve 4.5 AR 25mm internal
No blowoffs
No blowoffs
Tryna remember which video...but I saw a clip recently where a guy snapped his chain under load. As he struggled to then stay on the bike and turned the bars hard....the front tire rolled right off the rim! He may or may not have crashed anyway of course. The sudden lateral load seems to have been the cause of the roll off. Pssshh.
A tubeless tire? For that to happen the tire or rim must have been out of spec. I can't see how with the tire beads on the bead seats it could stretch up over the sidewall.wheelsONfire wrote: ↑Thu Sep 15, 2022 3:25 pmA guy here had a tire come off last week. Yes, he crashed. Don't know what wheels or tires. Heard it from a mech in a bike shop.
He didn't have enough air in the tire to give it sufficient support. MTBers learned long ago that while low pressure is great for comfort and grip you need enough support for hard cornering without burping a tire.StanleyM wrote: ↑Thu Sep 15, 2022 3:44 pmTryna remember which video...but I saw a clip recently where a guy snapped his chain under load. As he struggled to then stay on the bike and turned the bars hard....the front tire rolled right off the rim! He may or may not have crashed anyway of course. The sudden lateral load seems to have been the cause of the roll off. Pssshh.
I've been on tubeless for several years and hookless for the last three. As a bigger rider (192/90), I run 70 or 75psi. Never had anything but great riding wheels, lighter weight rims and self-sealing punctures from this set-up.
It often takes going to 100psi or slightly over to get the new tires to fully seat on the rim, so I can't imagine how high you'd need to go achieve a blow off. Worth paying attention during that process though - that's an important indicatory of a safe system.
If 'a mech in a bike shop' is telling tales of someone rolling a tubeless tire, I have to assume 'a mech in a bike shop' could have noticed that set-up was fully seated way too early (sub 50psi I'd guess), suggesting something was out of spec. Or someone wasn't actually using tires with a tubeless bead.
I'll see if I can find the clip. Well maintained bike with an experienced cyclist. Sudden steering inputs during crash avoidance and voila the front tire suddenly came off compounding matters. If hookless has a 72 psi cap,...what is the safe minimum? I guess if you get a puncture that self-seals you must stop and immediately air up ASAP too.Lelandjt wrote: ↑Thu Sep 15, 2022 4:09 pmHe didn't have enough air in the tire to give it sufficient support. MTBers learned long ago that while low pressure is great for comfort and grip you need enough support for hard cornering without burping a tire.StanleyM wrote: ↑Thu Sep 15, 2022 3:44 pmTryna remember which video...but I saw a clip recently where a guy snapped his chain under load. As he struggled to then stay on the bike and turned the bars hard....the front tire rolled right off the rim! He may or may not have crashed anyway of course. The sudden lateral load seems to have been the cause of the roll off. Pssshh.
I hope you're not running hookless with that pressurejs wrote: ↑Thu Sep 15, 2022 4:45 pmI've been on tubeless for several years and hookless for the last three. As a bigger rider (192/90), I run 70 or 75psi. Never had anything but great riding wheels, lighter weight rims and self-sealing punctures from this set-up.
His: Orbea Orca OMX
Yes, but on hookless rims rated at 100psi max, when running a 25mm tire.
At 90kg, if I run 60-65psi or less, I can feel the rim bottom out on potholes or rougher sections of road from time to time. Most tire pressure calculators (the one's I'd trust at least) suggest 80psi or more, but I'm quite happy with my numbers. They're well earned and well proven, and I'm not on tires with their own lower limit.
