ENVE Refresh?
Forum rules
LedZeppelin007
by LedZeppelin007
I’m going to put in a warranty claim even though it’s a relatively easy (but costly since I don’t have any more Enve tape, nipples, or a wrench for Enve nipples!) fix.
It’s just too weird of a thing to happen randomly like that.
Probably get it fixed and sell. But, this effectively ends my summer riding season. Thanks, Enve.
spdntrxi
by spdntrxi
rollinslow wrote:
Mon Sep 04, 2023 2:52 pm
I was looking at the 2.3 specs today and it appears Enve increased the weight by 75+ grams for XDR. Was that a subtle increase due to rim breakage? The website says do not use on gravel so perhaps that was a sign of things.
2.3 have never been gravel rated.. but yeah I noticed that increase in weight too. I dont think I would be buying them at 1274 +/- 2%
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
kode54
by kode54
crlincoln wrote:Quick question, which rim tape are people using with SES wheels, specifically 4.5, my lbs set my wheels up with Peaty's but I need to change them as the tape's are leaking...
I’m using 3M blue strapping tape. No issues.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
loup
by loup
Have been on 5.6 rim breaks with Extralite (1350g) for ages and still love them as arounder.
Looking forward to purchase a custom disc Wheelset with Extralite and Sapim CX-Super. I'm still stuck between 4.5 (@1285g) VS. 6.7 (@1325g). Tire should be Conti 5k TT 28c and/or 5k STR
Does anyone have actuall tire width readings for the combinations mentioned? I think 28c on the 4.5 with 32mm ext. width will be ok. But I'm not sure if 28c on the 30mm 6.7 will be a good choice (105% rule)
tmanley
by tmanley
spdntrxi wrote:
Mon Sep 04, 2023 4:20 am
LedZeppelin007 wrote:
Mon Sep 04, 2023 3:25 am
Anybody else had a broken spoke with the new wheels? I broke a DS spoke on a downhill on fresh pavement today. Very odd.
ever throw a chain ? on the other side of the cassette ? That's the only time I've even broke a spoke(s) on Enve wheels.
Same thing happened to me and it's the only time I've broken a spoke on my Enve's (which I've ridden multiple wheelsets over the past 12 years).
LedZeppelin007
by LedZeppelin007
Recently?
tmanley
by tmanley
I remember the chain getting sucked between the cassette and the spokes in a freak incident and observing what looked to be some damage to the spokes down around the j-bend area (this was on my 4.5 AR's). I knew it probably was only a matter of time before the spoke would break - I rode around w/ the damage for probably ~12 months before the spoke broke.
spdntrxi
by spdntrxi
I road around for ~2years.. a spoke would break about 1 every 6 months.. Finally I inspected it and found 4 more that had possible damage, so I had the whole thing re-laced with all new.
2023 Pivot E-Vault
LedZeppelin007
by LedZeppelin007
spdntrxi wrote:I road around for ~2years.. a spoke would break about 1 every 6 months.. Finally I inspected it and found 4 more that had possible damage, so I had the whole thing re-laced with all new.
What a shitshow lol. The wheels are fast AF and reasonably comfy, but I swear they bring nothing else to the table other than the Enve bling factor. Ugh.
spdntrxi
by spdntrxi
^.. but if you never threw a chain your failure is unexplained. Mine and tmanley is expected.
Yes I love me some Enve and have since old school 3.4 rim brake. I must have had alteast a dozen enve wheelsets over the years and the only ones with issue was my fault.
2023 Pivot E-Vault
LedZeppelin007
by LedZeppelin007
So, an update on my 4.5s. I was prepared to replace the spoke and true the wheel (not a big deal now that I have the right length spokes and the internal nipple wrench). However, Enve was concerned about the circumstances of the break and wanted me to send it in. So, I did.
Since these are my only wheels, I figured I’d pick up some 2.3s and then sell whichever one I liked less after I get the 4.5s back (apparently 4-6 weeks). I was able to get cosmetic blem 2.3s with Chris King hubs for a good deal from Brands Cycle (awesome people). I didn’t realize that pre-2022 Chris King HG11 hubs aren’t compatible with 12-speed (the oversized the splines to ensure better fitment with 11-speed cassettes). Using a file and some sandpaper I was able to remove very little material to get it to work and also got the newer HG body for later replacement.
I decided to run 32c GP 5k S TRs on the wheels. They measure 33mm.
Compared to the 4.5s, some interesting observations.
-Negatives:
-Not quite as light as you’d like with the Chris King hubs: 1278g not taped.
-Obviously, they lose some aero and you can tell a bit on downhills and flat sections.
-Less comfortable by a decent margin than the 4.5s, even with the larger rubber running 58 psi
-Positives:
-Stiff! Wow are they stiff. Don’t know whether it’s the layup or the hubs or some combo.
-Very light of course
-No issues with cross-winds at all. Was getting more movement from the frame.
-Handling is extremely responsive
-Once you get used to the stiffness and the reactivity, descending is a pleasure
-They really do climb like a stabbed rat, whether out of the saddle or in the saddle. Even though I’m larger (189cm, 85kg), they were still noticeable climbing
Honestly, the wheels leave more questions than answers. They are really, really good and, somehow, feel more durable and confidence inspiring than the deep sections. I rode a 100k with lots of hills, but with several flat sections on which I was riding between 23-30mph (had a tailwind for one significant section). Despite all of that, I rode faster than I usually do.
The same stiffness that made climbing a pleasure made some of the rougher sections unpleasant. It really makes me want to keep both wheelsets. Ugh. Choices….
spdntrxi
by spdntrxi
yeah CK's are not light... when I had the choice with my 4.5AR, I chose i9's because they were the lightest. I recently got 2.3 and they are shit to setup.. maybe it's the corsa pros. Michelin PowerCup were easy. Have to do the old tube first technique.. Front is done atleast.
2023 Pivot E-Vault
Tpduke112
by Tpduke112
Anyone run 7.8s with 28s? (Specifically PZero TLRs but curious any tires experience since the rim is "optimized" for 25s).
Bianchi Oltre XR4 Disc - 8.06 kg - Fast Race
Bianchi Specialissima Disc -7.59 kg Climby Race
Bianchi Sprint - Dirty Race/Practice Race
Bianchi Pista Sei Giorni - Dont Race
LedZeppelin007
by LedZeppelin007
Delete
LedZeppelin007
by LedZeppelin007
Re: 7.8s, they are 19mm internal and 29mm external, so you might be able to get away with a 28c tire, but probably not ideal. Maybe the 27c Enve tire.
I've had my gripes with Enve at times, but I'm back in the fold. The new 4.5s with the Innerdrive hub are fantastic, with the exception of having the loudest freehub known to man.
I picked up some 3.4s for a new gravel bike (there have been a lot of changes in my garage in the past two weeks). I intend to use them mostly with 32c tires GP 5k S TRs on long road rides as well as with wider and knobier tires for dirt
To my surprise, the 3.4s arrived direct from Enve sealed, but with the rim taped from the factory and the valve installed. The set weighed 1440g as it was delivered, probably a shade under 1400g without tape or valves.
Everything looked good and the tire mounting process went fine. However, the front wheel is, at least temporarily, out of true with the tire installed. Annoying.
The whole thing is making me wonder whether I should've just gotten a second set of 4.5s (which are also gravel rated) instead.
Any thoughts appreciated.
