Treptay wrote: ↑Tue Apr 12, 2022 10:17 pm
More data would be nice, but the problem is, latex and TPU tubes aren't recommended for use with rim brakes. As far as I know, all manufacturers of latex don't recommend it for use with rim brakes.
Really? While there's some small-fry, there's only two really big manufacturers of latex tubes (Challenge, and I think Vittoria?), and I don't recall them saying 'no rim brakes', but rather, be very cautious about using latex with carbon clincher rims, or maybe don't use that combo at all.
The following is from
Velo News:
From Challenge:
It is correct to say that latex tubes should not be used in carbon clincher wheels. It is correct to say that latex does not handle heat well compared to butyl.
Butyl rubber can support much higher temperatures for longer periods of time.
The reason why latex works on carbon clincher wheels (this is my personal opinion), is due to the ability of the rider. Expert riders are able to do descents with limited use of brakes and [thus] give the possibility to the equipment to cool down. Never reach extreme heating. The heat is generated on the external part of the rim and will take time to transfer inside the rim.
Generally between tire and rim strip, the tube has no direct contact to the carbon rim and if there is no rim strip it is on the cool part of the rim.
Heat in carbon [rims] does not dissipate fast and generally seems to be concentrated in the braking area.
Criterium and other types of riding do not have [the] problem of wheels heating, so latex can be used with no problem. As manufacturers, we do not know how consumers will use the product, and, to be on the safe side, we prefer to give warning not to use it.
— Alex Brauns
President, Challenge Tech
From Vittoria:
1. I have run latex with our 3T and Easton carbon clincher wheels with no issue at all, including significant descents in the mountains of Utah. I will, however, forward this to our product manager Christian Lademann for a detailed answer.
— John McKone
Vittoria Road Marketing
2. What is the heat tolerance of the average lightweight butyl tube and latex tube?
If the tube reaches the level of 100-140 degrees Celsius, all kinds of inner tubes will be destroyed.
And, how often do carbon clinchers reach temperatures that would lead a latex tube to fail?
This really depend on several factors, such as rim construction, -size, -resin and -tape. But mainly [it depends] on the end-user brake skills.
Agree that, “shorter, more powerful braking produces less heat buildup than does prolonged braking.” Similar to car brakes.
It’s not the tire bead, but the tube that cannot withstand the heat and give a sudden high pressure to tire bead. By the way, our tires run through a CQ that request 200 percent of the suggested maximum pressure. Example: Open CORSA CX 23mm 10.0 bar max tires have to withstand 20.0 bar at our derailing machine.
Is there another reason besides the heat issue that makes latex tubes unsafe for carbon clinchers?
Tubes are a rather sensitive product in general. Either Latex- or superlight Butyl tubes tend to explode suddenly, if not being used correctly. Some rules need to be followed:
1. Do not overheat the system
2. Do not lock the tube in between tire bead and rim hook
3. Prevent tube over-stretching in general — use recommended air pressure, rim tape and tube size
4. Prevent any sharp edges in the system
5. Prevent contamination with any oily substances
— Christian Lademann
Product Manager, Vittoria S.p.A.
