NEW GP5000S TR
Forum rules
I need your advice .
I'm finally jumping the tubeless bandwagon.
I've already decided that i will use Conti STR. But i'm in doubt wheter i should use 25mm/28mm combo or 28/28.
I'm mounting them on Roval Rapide CLX wheels.
I'm using them for racing in Belgium (and also training, but i prefer training om my race setup to build confidence).
im a 63kg rider fwiw.
Wil 25/28 be perfect for racing, but am i then risking more sidewall-slashes? Will 28/28 be to sluggish for racing?
thanks for your advice
Rapide front wheel is very wide. For Contis, which run true to size, I would not run a tyre narrower than 28mm on it - you get too little tyre and too much wheel rim poking out. I'd have worries about damaging the rim lip in potholes. It's also probably not the most aero efficient set up given the width of that wim. So 28/28 is your answer.LOWIEV wrote: ↑Tue Jul 04, 2023 9:19 amI need your advice .
Got to disagree: I've been successfully running tubeless 25s since 2016. 80 psi is fine for Orange Seal. I've even run Corsa Speed TLRs at 90-95 tubeless and currently have 24mm and 26mm Vittoria Corsa Pro at 80 psi. Some punctures seal quickly and some don't (and some not at all), but I find the same is true for 28s and 30s at lower pressures.
Bottom line is road tubeless works when you use Orange Seal regular, Dynaplugs, and I'll throw in Fillmore valves for easy inflation and no clogging. Although I always carry a spare TPU tube and boot for big cuts.
I’ve run 25mm tubeless tires at 100psi in certain races and for some PR attempts. Orange Seal handles most punctures fine, though yes on occasion you get one of those pinwheel fireworks shows with sealant. That happens at 70psi too with a large enough puncture.
Have been running GP5000S TR 25mm for about 1,000 miles at up to 97 psi and no lower than 85 psi.
I can confirm punctures have sealed with Effetto Mariposa. No issues with tyres blowing off hooked rims.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
- robbosmans
- Moderator
- Contact:
That’s the current tire with the pro’s run so no indeed
- ultimobici
- in the industry
- Contact:
Not necessarily as much of the extra weight is in the bead. More importantly the tubeless casing is likely to make for a harsh ride with tubes.joss wrote:Regular GP 5000 compared to the GP 5000s TR.
Both with TPU tubes.
Since the 5000s TS is heavier, would this tire be better agains puntures?
Running 30mm S-TRs for about 1000km now. The reason I have chosen them is that my wheels are hookless and have 25 internal rim width (I was using the wheels on my now deccommisioned gravel bike, I wouldn't buy hokeless for road bike if I haven't already had them).
My thoughts:
1)They are exactly 30mm wide on my wide rim
2)They are very grippy, it's crazy how much cornering grip I get in comparison to S-Works Turbo 28mm I was running on my previous bike with the same wheels
3)I am running them with TPU tubes for now. I will run them tubeless once I am in a place where I ride my road bike more.
4)The tires are very easy to mount on my rims. Easily doable without tire levers.
5)I think they are quite comfortable. I run them at 4.3bar rear, 4.2bar front. I guess I could easily go lower once I set them tubeless.
6)Still thinking about ordering normal hooked wheels and running standard 28mm gp5000. I run tubless on all my and my gf's bikes (gravel and mtbs) but we travel quit a bit with our road bikes and we don't get many punctures so I just don't see the point. Especially that those tires are heavy, expensive and not easily available.
My thoughts:
Running GP5000 clinchers on Rapide CLX they measured 29mm @70 psi as suggested below I wouldn't run 25mm as it will leave front outside rim very exposed to potential damage.LOWIEV wrote: ↑Tue Jul 04, 2023 9:19 amI need your advice .
I've used other tyres like Turbo cotton 26mm or Michelin Power Cup 25mm on the front they measure 28.5mm so not far off 28mm GP5000.
The difference in speed is defnitely noticeable. Went from a pair of Vittoria Corsa Next TLR 28mm to the GP5000S TR in the same size, the tyres roll more freely when not pedaling, and hold speed better. But at the same time, you do feel the road more and the vibrations.
That said, on my first ride, despite being out of action for 3 weeks, set a new PR on the same route I do.
Just swapped out my rear 28mm after 4800mi. There was one spot where I could start to see the casing threads underneath though the two wear indicator dots were still visible. A 25mm rear tire lasted 3800mi on mostly the same routes and season schedule.
