Pirelli P Zero TLR tubeless
Forum rules
bobones
by bobones
fulton wrote:
Fri Mar 01, 2024 11:19 am
Those who use 26 and 28mm Pirelli p zero race TLR tires, what sealant did you use(at what psi)? did they work?
Orange Seal regular, 70-80 PSI on 26s and 50-70 PSI on 28s and 30s (older version of P-Zero, 26s are SLs). Tried loads of other sealants including Silca, MilkIT, MucOff, OKO, Hutchinson, Decathlon, OS Endurance but nothing is as good as OS reg.
fulton
by fulton
bobones:
Thank you. would it be suitable at 85-90 psi?
and how easy is it to clean? and does it stain clothes if it gets on it?
Noctiluxx
by Noctiluxx
Just mounted a pair of Pirelli P Zero TLR 26mm on my R5. What PSI do you guys receommend? I'm 155lbs, 70kg. Oh and my wheels are Bontrager RSL 37
Bianchi Oltre XR4, De Rosa SK Pininfarina, Trek Madone SLR, Giant TCR Advanced SL, Cervelo R5 Disk, Giant Revolt
UrgentDelay
by UrgentDelay
To the guys who also rode Continental GP5000 S TR in the same size: is the ride quality better on P Zero (assuming both were ridden tubeless or both with tubes)?
TobinHatesYou
by TobinHatesYou
UrgentDelay wrote:
Sun Mar 03, 2024 11:47 pm
My 28mm P Zero Race TLR are 1mm narrower than my 28mm GP5K S TR once mounted, otherwise I think they feel a little bit better.
req110
by req110
Right. And much heavier. As 26mm pzero weighing same like 28mm gp5000 s TR.
SW SL8 RTP 56cm @ SH 9270 / Roval Rapide CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
UrgentDelay
by UrgentDelay
Thanks! From what I've read the consensus is that P Zero 4S is the most comfy, racing tyre. If it's more comfy than GP5000 of the same width on the label, it won't matter if the actual measured width is lower.
CONS: mentioned weight + also rolling resistance, 4.7W between 28mm GP5000 and 28mm P Zero Race TLR 4S SpeedCore, as measured by bicyclerollingresistance
thirdsun
by thirdsun
UrgentDelay wrote:
Tue Mar 05, 2024 7:33 pm
The 4.7 W difference will be at extra high pressure (90 PSI / 6.2 bar). Does anybody still ride at such high pressure? At more reasonable pressures the difference will be larger: 5.7 W at 5 bar and 7.1 W at 3.7 bar. Per wheel. So you have to double that number.
To me that's a significant difference. Unless you want puncture resistance at all costs I'd opt for the non-4S P Zero Race TLR which is very, very puncture resistant already and rolls slightly faster. Or the GP 5000 AllSeason TR, which rolls faster than both Pirelli but provides a little less puncture resistance.
  • Canyon Aeroad CF SLX 8 Di2
  • Cervelo Caledonia Rival eTap AXS
  • Vitus Venon Evo
  • Canyon Grail CF SL 8 Di2
jlok
by jlok
Is the profile of TLR like the clincher version, i.e. more pointed vs round like GP5000? That creates "problem" on wet surface. The rear tire skids easier than tires with less pointed profile.
gorkypl
by gorkypl
thirdsun wrote:
Wed Mar 06, 2024 9:01 am
100% this. In realistic scenario (slightly worn tyres, pressure around 5bar) it's probably around 12-15W penalty. That is a lot. And regular P Zero TLR are fantastic tyres.
Fuji Cross 1.5 - Shimano 105 5800 | Cinelli Superstar Disc - Record 12s | Custom steel Karamba - Ekar 13s
UrgentDelay
by UrgentDelay
It's a huge difference indeed, I didn't look like it this way. I only looked into the "4S" version, because it was recommended to me as the most comfy one. I even thought that "4S" stands for "for Speed" :D
Would you suggest a P Zero Race TLR SpeedCore then? Will there be a noticeable difference in comfort vs 4S? I don't care about puncture resistance when running tubeless.
The optimum speed/comfort I'm looking at right now is: GP5000 28mm S TR front, 32mm P Zero rear, don't know which ver will be the comfiest one though.
btw the difference between P Zero Race TLR 4S SpeedCore 28 and P Zero Race TLR SpeedCore 28 is 2W at 90 psi, so it would be c.a. 3W for lower pressures. No that noticeable anymore, hence if going for speed one should always switch to GP5000.
thirdsun
by thirdsun
UrgentDelay wrote:
Wed Mar 06, 2024 6:08 pm
In my opinion tire comfort primarily depends tire pressure. Most high end tires will ride well when used with suitable tire pressure. These days people seem to be aware that the right pressure is often lower than most assumed in the past. You should use Zipp's tire pressure calculator to see if you're in the right ballpark: https://axs.sram.com/guides/tire/pressure
I wouldn't mix different tire models front and rear. It looks silly. However using a narrower tire at the front for aerodynamics and a wider tire at the back for comfort is absolutely fine. I'd go with 28 mm front and 30 mm back.
Honestly, if puncture resistance isn't that big of a concern to you I'd probably go with the GP 5000 S TR. They are very fast and as you said the tubeless setup will do the heavy lifting when it comes to puncture resistance.
If you don't mind trading a little bit of rolling resistance for a huge gain in puncture resistance Pirelli P Zero Race TLR are excellent. By the way 4S stands for 4 Seasons - it's not a race tire ;)
I'd also consider GP 5000 AllSeason TR. They sit somewhere inbetween the GP 5000 and P Zero Race TLR - slightly faster, less puncture resistant but rather heavy for a road tire.
There's also the Tufo Comtura Prima TR which sounds promising on paper but I haven't ridden it yet.
TL;DR: Go with GP 5000 S TR or Pirelli P Zero Race TLR. 28 mm front, 30 mm back and make sure that you're not riding with too much pressure. Use Zipp's tire pressure calculator.
  • Vitus Venon Evo
UrgentDelay
by UrgentDelay
thirdsun wrote:
Wed Mar 06, 2024 6:32 pm
Thanks! When it comes to looks, I only care about the looks of people whom I'm taking over during a weekly "crit". However, people told me that P Zero is noticeably comfier than GP5000, but maybe it's not as noticeable with wider tires.
BTW I already rode with 28mm front and 32mm rear GP5000 S TR during the last season. Right now I'd basically go with as wide a tire as my frame would fit, but they're not making wider ones :) IMO comfort->training volume->speed, so comfort is supreme, but I guess there should also be some aero benefit for them aligning with the frame even better, than narrower tires.
About calculators, I've been using the SILCA's. Have you tested it against ZIPP? It put me at 64 PSI rear for 32mmWAM (narrow 19mm rims, changing to 25mm this year).
thirdsun
by thirdsun
UrgentDelay wrote:
Wed Mar 06, 2024 11:45 pm
Ok. Well, in my opinion tire pressure is the most important factor when it comes to comfort. Provided it's set correctly I find all mentioned tires (GP 5000 S TR, P Zero Race TLR, GP 5000 AS TR) equally comfortable. However The GP 5000 S TR is simply rolling faster.
Pesonally, I find Silca's recommendations way too high. About 1 bar too high, particalurly on my wider hookless rims. It's my understanding that Silca outputs values that prioritize rolling resistance above all else. However obviously there's a sweet spot between rolling resistance and comfort and in my experience it's located significantly below Silca's recommendations.
My suggestion: Try out Zipp's calculator and see how you like it. Fine tune those values to your liking.
  • Vitus Venon Evo
by 208
thirdsun wrote:
Thu Mar 07, 2024 7:59 am
General consensus is Silca's gives a higher value, but for me it gives me apx 5psi lower value for my rear tyre vs the Zipp calculator. Dunno which to believe. =\
