Winspace Hyper
Forum rules
Mcdeez
by Mcdeez
C36 wrote:
Mcdeez wrote:
Thu Mar 23, 2023 2:14 pm
C36 wrote:
Mcdeez wrote:Anyone tried 30c tire on the hyper 50s 1rst gen?
What's the meaurement mounted on the wheel and does it looks like a bubble?
Sent from my Pixel 6 Pro using Tapatalk
All depend the tire you install.
My 25mm gp5k were already 27+
My 23mm Cup are 25.3
But yes a 30mm tire (so around 31-33 real) will look like a bubble on a 26.5mm wide rim
Ok, im at 28c right now, im gonna keep it like that, love then
The questions is "what are you looking for"? you may have valid reasons to go 30 or to revert to 25mm labeled tires... all depends what you want...
Its for my all around bike, i clim and do long milles with one,since theres lots if pot hiles in my area more for comfort and aero ish, right in between.
elfuinha
by elfuinha
Ratchet Dtswiss type on the New Mega
Mcdeez
by Mcdeez
Thats nice
C36
by C36
What would be nice is a real seal on this freewheel. It’s an absolute pain to clean the FH each time it rains.
Zorka
by Zorka
What tool do you use for centering the Hyper (2020) wheels with carbon spokes?
On my first ride I hit some potholes and the front wheel is not 100% true anymore. Not too bad, only maybe 0.5mm side to side movement.
Mcdeez
by Mcdeez
Zorka wrote:What tool do you use for centering the Hyper (2020) wheels with carbon spokes?
Wheeltrue stand
Mcdeez
by Mcdeez
Hi everyone, i have to replace my bearings on the front wheel
I have a Disc Hyper 2021 wheelset, what part number is for the bearing?( Not ceramic, just regular)
The rim brake is not the same size
Ronin416
by Ronin416
Mcdeez wrote:Hi everyone, i have to replace my bearings on the front wheel
I believe it’s 6803
Zorka
by Zorka
Mcdeez wrote:
Mon Apr 17, 2023 11:50 pm
Wheeltrue stand
Wow. I´d like to see how you trued Hypers using wheelstand as a tool.
Mcdeez
by Mcdeez
I believe it’s 6803
I got the 6803 and the dont fit, it's for the Rim brake model i believe.
Ronin416
by Ronin416
Wheeltrue stand
No difference than re-truing any other wheel, just have to adjust it like an internal nipple and hold the outside nipple with spoke key and tension from under the rim tape.
SixThirteen
by SixThirteen
Mcdeez wrote:
Thu Mar 23, 2023 12:18 pm
I got a Conti 4000 SII in 28mm and on the Hyper 38 first gen and it blew up to 32mm and wouldn't fit inside my DA rim brake calipers
YMMV as they say
Scott Foil RC10 Ultegra 12 speed / Creston 50 - 7.9Kg
Zorka
by Zorka
Ronin416 wrote:
Thu Apr 20, 2023 2:25 am
Wheeltrue stand
Thank you. Any idea which tool I´d need to get? There are many types and sizes.
Ronin416
by Ronin416
Zorka wrote:
Zorka wrote:
Wheeltrue stand
Should be all here
https://youtu.be/UVzACwu9-YM
AgentScully
by AgentScully
Anyone running the new hypers? Contemplating between the 35mm and the mid section with a 46 front 54 rear. Still pretty light at around 1300gm for a mid/deep section wheel.
Merida Scultura 4000 rim
