Bora WTO
Forum rules
I've had the WTO60s on my Parlee RZ7 for about 800mi and in the bike stand, I only get ~3-4 rear wheel rotations following a light spin of the wheel. Is this normal? Seems the rear wheel should spin a lot longer. I used to have an old zipp 202 set and that wheel would spin forever. The RZ7 has a throughbolt axle.
A video would help to illustrate your "light spin" but generally, it should spin very freely for the life of the hub. Preload adjustment should be checked. Also, freehub bearings are shot? Too much wet riding?
I don't own a lot of campy/fulcrum wheels, only 5 or 6 pairs but all spin "forever" even with my abuse.
What is the procedure for checking the preload? I am not sure if that is the small collar piece with setscrew? Bike has never seen any rain.jlok wrote: ↑Wed Apr 26, 2023 1:55 pmA video would help to illustrate your "light spin" but generally, it should spin very freely for the life of the hub. Preload adjustment should be checked. Also, freehub bearings are shot? Too much wet riding?
https://www.campagnolo.com/media/files/ ... 22_ENG.pdf
Op001 - Instructions for the wheel hub adjustment
Instructions for the front and rear hub wheel with low medium high profile carbon aluminium adjustment
btw there are many nice technical manuals over here > https://www.campagnolo.com/WW/en/Support/download?td=4
Thank you all for the answers. I ended up going for the 45s!
Perfect match for the frame size! Braking is so much better than the old wheels!
Carrera Scatto/Ultegra R8000 11s/Campangolo Shamal Mille
- MrCurrieinahurry
- Moderator
Ah pic wont come up
Basso Diamante eps 12
Solved, thank you!
Check for rub on disc brake?jzinckgra wrote: ↑Wed Apr 26, 2023 1:14 pmI've had the WTO60s on my Parlee RZ7 for about 800mi and in the bike stand, I only get ~3-4 rear wheel rotations following a light spin of the wheel. Is this normal? Seems the rear wheel should spin a lot longer. I used to have an old zipp 202 set and that wheel would spin forever. The RZ7 has a throughbolt axle.
- MrCurrieinahurry
- Moderator
Have campagnolo said anything about that being normal looks pretty abnormal to me for a campagnolo wheel
To be honest it will take too much time to solve it that way... Returning it to BIKE24 and buying another set
THeir answer was:
I had the pictures checked again by the colleagues in the technical department. After that it looks like it's a slight manufacturing defect which doesn't look nice, but doesn't affect the function or safety.
THeir answer was:
- ultimobici
- in the industry
- Contact:
And this is why one should buy products from a proper dealer rather than online.octav wrote:To be honest it will take too much time to solve it that way... Returning it to BIKE24 and buying another set
THeir answer was:
So , I have returned them and bought a set of Bora WTO33 bright rim brake. They have just arrived on Friday morning yesterday went on the first ride they feel super nice with Vittoria Corsa NEXT TLR 26mm
Weight of wheels are 1420 grams(with Campy freehub)
